i have a little money to spend and wondered whether to buy a hyper212 evo or some quiet case fans first as i broke one 120mm fan in the back of my case so now i have 1 intake and 1 exhale....
anyway wondered your opinion
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/414687-well-i-am-stuck/
What cooler do you have now?
CPU: AMD 7800X3D Motherboard: NZXT B650E RAM: 32GB 5600 30-CL Corsair Vengeance DDR5 GPU: MSI Gaming X Trio RTX 2070 PSU: Corsair RM850i Monitor: Samsung 27" 4K thing Cooling:Noctua Chromax Black NH-D15: Case: NZXT H510 Black
https://linustechtips.com/topic/414687-well-i-am-stuck/#findComment-5579470
Id go with a BeQuiet! Pure Rock. It's much better then the 212 evo on terms of being quiet and having lower temps
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/414687-well-i-am-stuck/#findComment-5579495
-snip
I believe the word you're looking for is exhaust.  :)
I'd probably get case fans. A 212 EVO isn't what you'd call quiet.
look at my page for current pc
so yeh using stock cooler
https://linustechtips.com/topic/414687-well-i-am-stuck/#findComment-5579500
No his computer is a sentient computer being that he has made it his slave.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/414687-well-i-am-stuck/#findComment-5579504
I'd get more case fans though. Things can get pretty toasty in the box, get some more intake fans if you want less dust!
https://linustechtips.com/topic/414687-well-i-am-stuck/#findComment-5579521
the case fans will be my next purchase i guess after the after-market cooler
https://linustechtips.com/topic/414687-well-i-am-stuck/#findComment-5579564
The way i see it, the CPU cooler has priority since it will have the biggest impact in reducing temps and noise. I would consider the H7 from CRYORIG since it looks like it outperforms the hyper 212 evo at the same price...and looks nicer :P
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565&cm_re=cryorig-_-9SIA4UF2DZ6565-_-Product
Now, case fans are different, you can get quiet cheap case fans from good companies, when you go premium on fans you really start talking about deminishing returns.
http://www.amazon.com/ARCTIC-F12-PWM-Rev-Dynamic/dp/B00H3T1KBE/ref=sr_1_26?s=pc&ie=UTF8&qid=1437771619&sr=1-26
Buying a couple of fans of this price range could give you enough airflow quietly without breaking the bank, nothing special about them, but they are just case fans...
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/414687-well-i-am-stuck/#findComment-5579663
