This will be my first PC build, and I'm going for more of a quiet build. I was wondering what cpu cooler is relatively quiet, as I won't be overclocking. Would a stock cooler be fine? I'd like to stay under 50, lower if possible. The CPU is an I5-4590 and the case is a Define R5.
https://linustechtips.com/topic/414650-quiet-cpu-cooler/
be quiet! Shadow Rock 2
Cryorig H5
We dont know if stock cooler will be fine because we dont know what CPU you have. If it is Intel stock cooler and i5 it should be tolerable as Intel stock coolers run fairly silent considering the RPMs but it is still audible.
https://linustechtips.com/topic/414650-quiet-cpu-cooler/#findComment-5578984
BeQuiet! Shadow Rock 2
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/414650-quiet-cpu-cooler/#findComment-5578987
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/414650-quiet-cpu-cooler/#findComment-5578994
Cryorig H5
Sorry, realized that right away. I don't know if its worth $50 for noise over a stock cooler. Would you say so?
https://linustechtips.com/topic/414650-quiet-cpu-cooler/#findComment-5579015
Dark Rock Pro 3.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/414650-quiet-cpu-cooler/#findComment-5579129
I do think a dual tower heatsink would be overkill, if you are buying a heatsink for a locked CPU, i'd say things that are normally small are more important, like aesthetics, ram and PCIe clearence and well, price. The dark rock pro 3 is rated at 250W TDP, your CPU will never go near half of that. Any single tower cooler from a reputable brand like thermalright, be quiet, noctua, phanteks or CRYORIG should be plenty.
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565&cm_re=cryorig-_-9SIA4UF2DZ6565-_-Product
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF1W87430&cm_re=cryorig-_-9SIA4UF1W87430-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709020&cm_re=phanteks-_-35-709-020-_-Product
http://www.newegg.com/Product/Product.aspx?Item=9SIA68V2326642&cm_re=be_quiet-_-9SIA68V2326642-_-Product
http://www.newegg.com/Product/Product.aspx?Item=9SIA68V21E0641&cm_re=be_quiet-_-9SIA68V21E0641-_-Product
http://www.amazon.com/ThermalRight-Macho-size-reduced-HR-02/dp/B008SAOCHG/ref=sr_1_3?s=pc&ie=UTF8&qid=1437769362&sr=1-3&refinements=p_4%3AThermalright%2Cp_36%3A1253504011
http://www.newegg.com/Product/Product.aspx?Item=35-106-216
Just a bunch of decent products under 50 bucks that i think would serve you well. Personally, i would go with the CRYORIG H5A, 140mm fan, great quality, big old heatsink, overall very nice, specially if you ain't overclocking it should be whisper quiet
*I left out noctua for the price and CM cause they simply don't make particularly quiet coolers
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/414650-quiet-cpu-cooler/#findComment-5579406
Dark Rock Pro 3, or Thermalright Macho Rev B. I prefer the looks of the Dark Rock Pro 3 (Own it myself), but I also have seen reviews/tests where the Thermalright Macho leads the pack! It is also much less than the Dark Rock Pro 3. Although if you want looks and beast performance, the Dark Rock Pro 3 is the best you can buy in my opinion.
I like good humans and good food
https://linustechtips.com/topic/414650-quiet-cpu-cooler/#findComment-5579412
You should be able to pick up a Zalman FX-70 for 50$. If you CPU is <60 watts that's the best you can do because it makes absolutely no sound. For high power CPUs the other ones have some good suggestions.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/414650-quiet-cpu-cooler/#findComment-5580236
