I'm pretty sure this combination is not going to work, the Powercolor 390 you listed is a 2.5 slot card and would need to sit through the side panel in the Elite 130.
Pfff, 0.5".... just squeeze it in there!  :P
Just use one of these and a lot of force. It'll fit. It might not work when you're done, but it'll fit... :D:P
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
Why not? I ran a 290 in a Node 304 and it was fine. :)
lot of 390's have bulkier coolers, msi,powercolor being 2.5 slot, nitro being long
but my main reason being more personal, I'm currently sitting in 32C ambient temperature, with outside being 37-38ish with no AC unit, there's no headroom to OC a 390 in an ITX case in this environment
The Gigabyte 390/x now uses a dual-fan windforce cooler which is shorter than any other 390/x on the market. Would be a good choice for an ITX build if that's the GPU you wanted to use.
But yeah, I totally get where you're saying. I was easily OCing my 290 in the Node 304, but my ambient temps are way lower here (~20-25*C). Nvidia blower cards are definitely more ideal for ITX systems, especially tiny cases like the Node 202. ;)
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
I'm especially looking forward to your explanation of how you hope to fit two 980 Tis in such a tiny case AND power them with a 450 Watt supply!
Very carefully.  :P
Edit: If a monitor and keyboard aren't included in the price then this should do.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($103.99 @ Amazon)
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($129.99 @ Micro Center)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($109.95 @ B&H)
Total: $1698.25
Generated by PCPartPicker 2015-07-24 14:06 EDT-0400
A little unbalanced but who cares. (If that bothers you too much you can get an R9 Fury or 980
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
Very carefully.  :P
Total: $1698.25
Again, you're $200 over budget.
Around $1,500 is what I had in mind. I'm also not against resellers for certain components.
1500 USD isnt a console killer, thats a SFF build...
i can buy 3x PS4 for 1500 USD.... if i had the intelligence to serial connect or pool their computing power they would smoke most 1500 USD builds unless you spent 90% of that 1500 USD budget on a Xeon...
But that is beside the point... Console Killer is a term used for small PCs that has better performance then consoles at console prices (which is 499 for the XBONE/PS4)
No it isn't. If you can't afford either, you can't afford either. It doesn't matter if it's 20 dollars over budget or twenty million -- it's more than OP has said he can afford.
Well that's quite a bit of over exaggeration there. Though I guess I'll give it to it's just that the extra $200 gives you a really nice boost in performance.
It would fine if OP went with an R9 Fury or 980.
It's not an exaggeration at all. People set budgets for a reason, it's what they are either willing or able to afford. You are being unhelpful when you completely ignore every requirement that OP has given, including the fact that the case OP is using has an integrated 450 Watt power supply. I would recommend a 970 or 980 and nothing more.
I personally wouldn't trust an integrated PSU unless the OEM of that PSU is Delta, Super Flower or SeaSonic.
If OP went with an R9 Fury or 980 they'll be closer to their budget. OP could also go with a 2x4GB kit instead of a 2x8GB kit.
It's Fractal Design, I'm not particularly worried about it exploding.
True, but it would seem Fractal doesn't use the best of OEMs.
Also I'd figure that it'd be easier to transport something like the prodigy because it has handles so that'd help. Also fully modular PSUs help keep clutter down and improve air flow.
Okay this better?
 inb4 Nooooo it's $16 over budget u cheeky cunt
Total: $1515.30
Generated by PCPartPicker 2015-07-24 17:10 EDT-0400
Okay this better?
Total: $1515.30
Assuming OP is set on the case that they want, I would go for the 970 or 980 over Fury. They use less power (which is good if you're using a 450 Watt PSU) and produce much less heat, which is good in a confined space.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($64.05 @ Amazon)
Motherboard: ASRock Z97E-ITX/ac Mini ITX LGA1150 Motherboard  ($121.98 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($99.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($324.99 @ NCIX US)
Case: Cooler Master Elite 110 Mini ITX Tower Case  ($34.99 @ Micro Center)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($86.98 @ OutletPC)
Total: $1072.84
Generated by PCPartPicker 2015-07-24 22:46 EDT-0400
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
No sense in a 4790k for the sole purpose of gaming. Especially when the budget is only $1500
A 4790k is quite better than the 4690k for other  things. I'm constantly sitting at 100% utilisation on a 4 thread machine, and it's being really sluggish. I missed that fact that the OP was just gaming on the thing.
@nerdyotter If you are doing solely gaming on the thing, get an i5 4690k, but if you are doing other things on the machine, then I would highly suggest getting an i7 4790k.
If I've said something wrong, please correct me
My Builds:
Peripherals:
Keyboard: Roccat TKL Pro Cherry MX blue, Mouse: Roccat Kone XTD, Headset: Currently apple earbuds, planning to upgrade to hyperx cloud or hyperx cloud 2
Really Old Desktop
 Processor: Intel Core i7 920, Motherboard: Gigabyte GA-FX58-DS4, RAM: 9GB Corsair XM3 (3*3GB in triple channel) 600 or 800mhz, Graphics Card: Asus 8400GS passive, Asus GT630 4GB if i can get it working, Case: Cheapo Throwout case with most of the standoffs missing, HDD: Some old 80GB hard drive, PSU: Thermaltake Toughpower 550w, Monitor: 32" Kogan TV, OS: Fedora 13
 Laptop Which I Use For Everything:
Processor: Intel Core i5 3337U, RAM: 8GB (2*4GB) 1600MHZ, Graphics Card: Nvidia 710m HDD/SSD: WD Black2 Dual Drive, OS: Windows 8.1
 40 GB/s Network Tester
Processor: Some really good Intel Core i3, Motherboard: Gigabyte GA-H67N-USB3-B3, Ram: Corsair Value Select 4GB (2*2GB) 1600MHZ, Graphics Card: Integrated, Case: Some 1U rackmount mini-itx case with no front bays, HDD: Seagate Momentus 5400, 250GB 2.5" 5400RPM, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 40Gb/s QSFP+ PCIe 3.0 8x NIC, Monitor: any ones lying around, or 32" Kogan TV, OS: CentOS 6.2 (I Think)
Planned 100Gb/s Newtork Tester
Processor: Intel Core i7 4790k, Motherboard: Asus Maximus VII Impact, Ram: Kingston or G.Skill 8GB 2400MHZ Low Profile, Graphics Card: Integrated, Case: 1U Rackmount ITX case, HDD: Samsung 850 EVO 120GB, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 100Gb/s PCIe 3.0 16x NIC, Monitor: Any lying around or 32" Kogan TV, OS: Fedora 22 or CentOS
"Console replacement" then, I guess.  I just a PC that's around the same size as a modern console (which is why I chose the Node 202) with much more power.
Total: $1072.84
Thank you for the suggestions!  I'd love to take the storage options into account, but the Node 202 (the case I'd want to build this PC in) only supports dual 2.5" drives.
Okay let's be realistic here. Using a fully modular power supply isn't going to cause a noticeable difference in performance it's really an aesthetic thing.
A bit confused why you would choose a 620w 80+ bronze seasonic for $80, rather than the Evga SuperNOVA which is 80+ gold and 650w for $85 though.
I'm using an i2 q6600, so we probably have different definitions of sluggish... Although this thing was a monster when it came out back in 07.
Eh Fully modular I'd think would be easier to work with.
i5 3337u
1.8ghz. My one is pretty damn sluggish. Notice i said 4 thead.
My Builds:
Peripherals:
Really Old Desktop
