I'm currently thinking about building a "console killer" gaming PC after lugging around my massive InWin GRone case to several LAN parties in the past.  I'm strongly considering building the case in Fractal Design's new Node 202 Mini ITX case once it's available for purchase at various online retailers.
Until then, what sort of suggestions do the Linus Tech Tips forums have in the way of components to put into this build (with a budget of around $1500)?
https://linustechtips.com/topic/414289-components-for-a-console-killer-case/
Screw console killers, how about a console slayer. (Also console killer is an annoying thing because it's like you're going off the base price of the unit you might be able to get around 30 to 50 fps @ 1080p with max/ultra settings (which isn't bad) though to beat a console it's ideal to have longevity and performance in mind (60+ fps @ 1080p ultra/max or 30-60fps @ 1440p ultra)
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($299.99 @ Micro Center)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($103.99 @ Amazon)
Thermal Compound: Arctic Cooling MX4 4g Thermal Paste  ($8.26 @ Amazon)
Motherboard: MSI X99S SLI Krait ATX LGA2011-3 Motherboard  ($285.99 @ NCIX US)
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked+ ACX 2.0+ Video Card (2-Way SLI)  ($679.99 @ NCIX US)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($104.99 @ Micro Center)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($109.95 @ B&H)
Case Fan: be quiet! SilentWings 2 50.5 CFM 120mm  Fan  ($23.90 @ Newegg)
Case Fan: be quiet! SilentWings 2 60.4 CFM 140mm  Fan  ($24.90 @ Newegg)
Monitor: Dell U2715H 60Hz 27.0" Monitor  ($497.29 @ B&H)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($166.60 @ Amazon)
Other: CableMod E-Series Black/White ($89.95)
Other: EVGA SLI bridge ($30.00)
Total: $3936.63
Generated by PCPartPicker 2015-07-24 03:58 EDT-0400
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
Total: $3906.63
Generated by PCPartPicker 2015-07-24 03:56 EDT-0400
I love Alt-J  :D If you press the Alt + J key on a Mac, it makes a triangle like their logo.
CPU: Intel Core i5-4460Motherboard: Asus Z97-A/USB 3.1Memory: G.Skill Ripjaws X Series 8GBStorage: A-Data Premier Pro SP900 128GBGPU: Sapphire Radeon R9 290 4GB Tri-X OC Video CardCase: Corsair SPEC-01 REDPower Supply: EVGA 600BNetworking Card: TP-Link TL-WDN4800Monitor: Asus VG248QE 144Hz 24.0" MonitorKeyboard: Razer BlackWidow Tournament Edition (Cherry MX Blue) Mouse: Logitech G100s | Quote me and say "Dope Flamingo" if you actually read this.
Total: $3906.63
Sweet $1500 ITX build there...
Obviously I do too (as of late I've been listening to a lot of OMAM (Of Monsters and Men)) Also yeah I know.
@othertomperson I know  ;)
(I know $700 to $1500 you can make a console "killer" but the aesthetic and quality generally have to take the back seat, and at least for me that's sort of hard to do.)
So I figure why not just make a console slayer and do it reliably and fashionably too.
This probably isn't the best, but it's a start
http://pcpartpicker.com/p/V4BzrH
If I've said something wrong, please correct me
My Builds:
Peripherals:
Keyboard: Roccat TKL Pro Cherry MX blue, Mouse: Roccat Kone XTD, Headset: Currently apple earbuds, planning to upgrade to hyperx cloud or hyperx cloud 2
Really Old Desktop
 Processor: Intel Core i7 920, Motherboard: Gigabyte GA-FX58-DS4, RAM: 9GB Corsair XM3 (3*3GB in triple channel) 600 or 800mhz, Graphics Card: Asus 8400GS passive, Asus GT630 4GB if i can get it working, Case: Cheapo Throwout case with most of the standoffs missing, HDD: Some old 80GB hard drive, PSU: Thermaltake Toughpower 550w, Monitor: 32" Kogan TV, OS: Fedora 13
 Laptop Which I Use For Everything:
Processor: Intel Core i5 3337U, RAM: 8GB (2*4GB) 1600MHZ, Graphics Card: Nvidia 710m HDD/SSD: WD Black2 Dual Drive, OS: Windows 8.1
 40 GB/s Network Tester
Processor: Some really good Intel Core i3, Motherboard: Gigabyte GA-H67N-USB3-B3, Ram: Corsair Value Select 4GB (2*2GB) 1600MHZ, Graphics Card: Integrated, Case: Some 1U rackmount mini-itx case with no front bays, HDD: Seagate Momentus 5400, 250GB 2.5" 5400RPM, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 40Gb/s QSFP+ PCIe 3.0 8x NIC, Monitor: any ones lying around, or 32" Kogan TV, OS: CentOS 6.2 (I Think)
Planned 100Gb/s Newtork Tester
Processor: Intel Core i7 4790k, Motherboard: Asus Maximus VII Impact, Ram: Kingston or G.Skill 8GB 2400MHZ Low Profile, Graphics Card: Integrated, Case: 1U Rackmount ITX case, HDD: Samsung 850 EVO 120GB, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 100Gb/s PCIe 3.0 16x NIC, Monitor: Any lying around or 32" Kogan TV, OS: Fedora 22 or CentOS
I'm especially looking forward to your explanation of how you hope to fit two 980 Tis in such a tiny case AND power them with a 450 Watt supply!
The case can be portable and have some airflow.
$1122:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: Enermax ELC-LM120S-TAA 105.7 CFM Liquid CPU Cooler  ($72.98 @ OutletPC)
Motherboard: ASRock Z97M-ITX/AC Mini ITX LGA1150 Motherboard  ($109.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2400 Memory  ($84.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($177.89 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($314.98 @ Newegg)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($34.99 @ Newegg)  <<I would build a handle into/onto the case
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($65.98 @ Newegg)
Total: $1081.79
Generated by PCPartPicker 2015-07-24 05:06 EDT-0400
$1122:
Total: $1081.79
the 390 is a good card, but I would not put it in an ITX case
I was looking at the node 202, and it's a stunning case, but how in the world do you fit a graphics card in that? The expansion slots seem to be parallel to the motherboard, so does it use a PCIe extension cable? But if so, shouldn't it be attached to something rigid other than the expansion slot?
Tip to those that are new on LTT forum- quote a post so that the person you are quoting gets a notification, otherwise they'll have no idea that you did. You can also use a tag such as @Ryoutarou97 (replace my username with anyone's. You should get a dropdown after you type the "@")to send a notification, but quoting is preferable.
Feel free to PM me about absolutely anything be it tech, math, literature, etc. I'll try my best to help. I'm currently looking for a cheap used build for around $25 to set up as a home server if anyone is selling.
If you are a native speaker please use proper English if you can. Punctuation, capitalization, and spelling are as important to making your message readable as proper night theme formatting is.
My build is fully operational, but won't be posted until after I get a GPU in it and the case arted up.
It has to.
It has to.
That's the solution I was thinking of, but then isn't the card only attached to the expansion slot? It's only one small screw holding that thing up and there is no way it doesn't rattle.
You make me want to look into how the node works now... gotta LoL game to play =P
I'll look into it, good luck with the LoL game.
The whole point of this build was to use the Node 202 and have it be portable - like a console. ;)
Why not? I ran a 290 in a Node 304 and it was fine. :)
@nerdyotter - Here's what I'd put in the Node 202 with a budget of $1500:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
CPU Cooler: Deepcool GABRIEL 61.9 CFM CPU Cooler  ($39.99 @ Newegg)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($89.99 @ SuperBiiz)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($42.99 @ Newegg)
Storage: Crucial M500 960GB 2.5" Solid State Drive  ($320.75 @ Amazon)
Video Card: Zotac GeForce GTX 980 Ti 6GB Video Card  ($648.95 @ Amazon)
Total: $1437.61
Generated by PCPartPicker 2015-07-24 09:07 EDT-0400
Cost of the case is not included, but this would be ballin! :D Can always go for a smaller SSD to help it fit your budget. I say, spend the money where it matters for gaming - on the GPU. There's no need to overclock the CPU in a tiny case like this, so don't bother with a k-CPU and Z97 board. This i5 and board combo would be more than adequate. ;)
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
It uses a PCIe riser card. You plug the GPU into the PCIe slot and screw it in like you would in a normal case, except it's at a 90 degree angle.
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
No sense in a 4790k for the sole purpose of gaming. Especially when the budget is only $1500
No need for 16GB ram or a $218 motherboard either. ;)
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
There's a GPU chamber and a support bracket that slides for differently sized GPUs.
https://youtu.be/YsDW0Q9Jeas?t=3m35s
How do I embed a video, and in a case like this (event, not the node), should I tag you, requote, or is there a better way to send you a notification
Cool, thanks! I can't really see in the photo, is there a 90 degree bend on the other side of that riser card? Is it rigid?
Edit: Nevermind finished the video, yes it is and this looks amazing. You could probably fully liquid cool this thing!
I'm pretty sure this combination is not going to work, the Powercolor 390 you listed is a 2.5 slot card and would need to sit through the side panel in the Elite 130.
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
