Hey, I am going to buy a new gaming rig and this is my first custom build!
1. Budget & Location- $1500 USD MAX- Will be buying in the US.
2. Aim - Gaming and some Photoshop etc (Editing)
3. Monitors -  1 I guess :3
4. Peripherals - I will need a Keyboard and a Mouse. (Doesn't apply to budget)
5. Build:
  • CPU - Intel i5 4690K
  • CPU Cooler - NZXT Kraken X41
  • Motherboard - MSI Gaming 5
  • RAM -  Kingston HyperX Fury Red 8GB (2 x 4GB) DDR3-1866 Memory and Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory
  • Storage - WD Caviar Clue 1TB 7200 RPM HDD and a Samsung 850 EVO 250 GB SSD
  • GPU - MSI Radeon R9 390X 8GB
  • Case - NZXT Noctis 450
  • PSU - EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX
This is my build : http://pcpartpicker.com/p/qLDQQ7
Should I go with a MSI R9 390X or the Sapphire 390X or the Gigabyte R9 390X?
https://linustechtips.com/topic/414234-first-gaming-pc-build/
Get a vega gs or G2 series PSU. It will be much more reliable then those corsair CX series... Looks good to me though. The NZXT x41 Kraken compares to the Corsair h100i and is only a 120mm rad.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573390
upgrade to a gaming 9 looks so much better
A gaming 9 cost like $290 I though.. I think it does atleast. Plus the difference In looks is almost none.
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573410
It would be little editing(mostly Photoshop) so I decided to save some money with the i5. Should i change to a x61 Kraken since I will be OCing?
Doesn't really matter. The x41 and x61 temp difference aren't to big.
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573422
getting a mobo for 300$ is insane as it does not affect performance.... a 100-150$ Mobo makes basically the same as long as you are not heavily overclocking and try to squeeze every mhz you can get out of it
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573448
The cx series produces more heat.Instead go with some evga
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573462
So, change to a evga PSU and go with the H100i cooling?
I'll stick with the Gaming 5, I'll save my money.
Parents will buy Mous and Keyboard; I'll be paying for the rest :/
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573466
no no the x41 performs better then the corsair h100i. My bad it's a 140mm rad not a 120mm.
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573478
Added much better options that outperform what you had while being much cheaper.
http://pcpartpicker.com/p/tQ7s7P
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573485
PHXQwerty: I'd make these changes:
PCPartPicker part list: http://pcpartpicker.com/p/Z23NVn
Price breakdown by merchant: http://pcpartpicker.com/p/Z23NVn/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($74.90 @ Newegg)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($135.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($94.99 @ Adorama)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($105.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($429.98 @ SuperBiiz)
Case: NZXT Noctis 450 ATX Mid Tower Case  ($134.99 @ Micro Center)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($73.15 @ Amazon)
Total: $1322.37
Generated by PCPartPicker 2015-07-24 01:25 EDT-0400
Ram for better upgradeability (you could also stick with your ram brand and type and go for 2x 8gb) and an other PSU and i personally prefer air coolers over small watercoolers (the dark rock is a beast). you could also go with a xeon 1231v3, costs almost the same but has 8 threads and is non-oc-able
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573495
Changed the PSU!
http://pcpartpicker.com/p/4TWJdC The PSU you picked was better then the corsair but the one in this list is better. It was made by SeaSonic which are some nice high quality PSUs. This right here is just fine and should work perfect.
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573519
Add your psu to this build instead some of the options on that one are really dumb. http://pcpartpicker.com/p/R7P8cf
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573527
No. Mine are just fine, all I did was change the ops PSU. Even though the x41 kraken is just a 140mm rad it has temps that are better then the corsair h100i. The ram, honestly 16gbs is more then enough and quad channel ram will be good.
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573536
The h100i is a piece of shit that is over priced. The one I put on is cheaper and better, two separate dual 4s isn't cost effective and the ssd choice doesn't make sense.
with that in mind the psu I grabbed also works fine.
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573546
No need to go haywire. The cooler you chose I can't even find a review on YouTube of it in English. The corsair h100i is one of the most used CPU AIOs. The x41 is a good CPU cooler which will also compliment the NZXT Noctis 450 because of the LEDs it has and being so small and effective. The PSU you chose is fine but some people like fully modular and the 80+ Gold will also help the electricity bill. A.sp the SSD choice doesn't make sense? Yeah crucial is also one of the best SSD budget SSDs for the speeds it has to offer.
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573573
CPU Cooler: NZXT Kraken X41 106.1 CFM Liquid CPU Cooler ($94.99 @ NCIX US)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory ($48.49 @ SuperBiiz)
Memory: Kingston HyperX Fury Red 8GB (2 x 4GB) DDR3-1866 Memory ($51.99 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($97.95 @ OutletPC)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($75.98 @ Newegg)
Total: $1342.84
Generated by PCPartPicker 2015-07-24 01:49 EDT-0400
@PHXQwerty Here, this will do. The ram I chose is to just make it look pretty, the only true difference in the two kits is the color. The SSD I chose just to match the build since the NZXT noctis 450 has the 2.5inch bays showcases on top of the basement it has for the PSUs.
https://linustechtips.com/topic/414234-first-gaming-pc-build/#findComment-5573617
