What is best for r9 380? i3 or 4.2 GHz G3258
Solved by TheRetiredSlave,
I'd go i3. In both tomshardware's and Anandtech's reviews of the g3258 (OC'd), it only performs only a little better than an i3 in some very heavily single threaded games. The i3 can perform dramatically better in multithreaded tasks, and generally performs the same or better in games than an OC'd g3258.
The i3 is more expensive, but I'd consider it worth the money to have the guaranteed performance instead of needing to rely on overclocking luck. Use the stock cooler and an affordable motherboard, and you'll have a reasonably affordable good gaming PC.
