GPU for 1080p 60 Hz monitor
nims0c
I'm planning to buy a 1920x1080 60 Hz IPS monitor. What GPU should I get that will deliver around 60 fps with relatively high settings (maxed out where possible, somewhat high on more demanding games)?
(I was contemplating a GTX 970 but some say it's overkill and that you need 1440p or 144 Hz to take full advantage of it.)
i5-4690K@4.5 GHz // Asus Z87-Pro // HyperX Fury 8GB DDR3-1600 // Crucial BX100 250GB // Sapphire Nitro R9 390 // EVGA SuperNOVA 750W G2 // Fractal Design Define S // be quiet! Pure Rock & Pure Wings 2 // BenQ XL2730Z // Corsair Vengeance K70 // Logitech G403 Wireless // Sennheiser HD 598 SE
280X
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
GTX 970 100% isn't overkill, it's perfect for 1080p 60Hz @ 60fps, it will not do well at 1440p 144Hz.
I'd go for the GTX 970, or the r9 390, which ever you like the look of better/is cheaper, because both will perform pretty much the same.
(Or if you play games that are more optimized for nvidia cards then go for the gtx 970, same the other way round.)
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
I smell someone trying to bring something to the green side
THE FORCE AWAKENS
970 will not get 60fps all the time at 1080p, if you like playing Ultra everything.
CPU: AMD 7800X3D Motherboard: NZXT B650E RAM: 32GB 5600 30-CL Corsair Vengeance DDR5 GPU: MSI Gaming X Trio RTX 2070 PSU: Corsair RM850i Monitor: Samsung 27" 4K thing Cooling:Noctua Chromax Black NH-D15: Case: NZXT H510 Black
THE FORCE AWAKENS
But I recommended both the 970 and 390, said they perform the same so get whichever is cheaper (Which is the r9 390 in most countries), then I said or you can pick based on which games you play if they are optimized better for one side, which just happens to be nvidia with the last couple big releases (Thx to gameworks ectect) so I used tht as an example instead of AMD  :wacko:
280X
970 would be a slight overkill, but you'll atleast be sure you'll get 60 fpd most of the time!
maybe get a 280X or a non-x 290?
If you want to max out everything under the sun and never drop below 50fps ever look at a 390 or 970.
If you can live with turning a few things down a tiny bit in a few games that are not amazingly optimized a 290 is like 240$ and is pretty damn good.
I've never overclocked before but it seems pretty easy based on some video guides. Would your responses change if I said I wanted to overclock the GPU?
No, it will still not get 60FPS ultra everything, I know this because I have one!
Well the 970 is known for being a beast overclocker (levels out with the 980 at stock when you overclock it decently) but still it's perfect for 1080p when overclocked as well, just means the newer more demanding games will be playable at ultra (Maybe with AA settings not maxed out though on some games) @60fps
not really, you'll void your warranty (maybe) but it's pretty save to OC your card.
if i where you i'd get the 970. slight overkill is not a bad thing, and actually enhances your gaming experience since your card will be more silent!
Do you like warenty?
Can they tell you overclocked a CPU or GPU? I thought you could just revert it to factory speeds.
Anyway, it just seems like everyone is all about overclocking so I figured it can't be that harmful to try myself.
Anyway, it just seems like everyone is all about overclocking so I figured it can't be that harmful to try it myself.
please, do try to overclock! i overclocked my GPU and the gain in performance is definitely noticable.
you can tell if a GPU has been overclocked tough. i believe there are ways to re-flash the card with the stock clocked/untampered software, tough it isn't a 100% fix.
I like R9 295X2
( ͡° ͜ʖ ͡°)
GTX 980 or higher, it's 2015.
Yo soy el hombre murciélago
I'm planning to get a 980 Ti or equivalent in the future, so I don't see the point of overspending now.
Well if you can it would be better to just get that and forget about the 970 for now, but if you can't you could always get a 970, then SLI it later on, that will give you the same performance as a 980Ti. (Or if you find 970 to be more than enough you can just get a completely new GPU 3-5 years down the line)
it's incredibly wiser to save your money, wait and get the best you can , having only 1 purchase if you have the patience and discipline to do so man
honestly, it's in your best interest, you'll lost out on this card, have sub par perf and lose out reselling it to upgrade again.
The thing is I want a 144 Hz IPS variable-refresh rate monitor down the road. These displays are so expensive right now and require an equally expensive graphics solution. That's why I was thinking of a 1080p 60 Hz and an appropriate GPU for now.
I like R9 295X2
( ͡° ͜ʖ ͡°)
No. Get an Nvidia card.
Black and green build, I call it "Murphy". - CPU: Intel i5 4690k at 3.5 GHz - GPU: Gigabyte G1 Gaming GTX 980 Ti - Motherboard: Gigabyte Z97X SOC Force - RAM: 8GB 1866 MHz Corsair Vengeance Pro (gold) - PSU: EVGA SuperNova 750 B2 - Storage: 240GB Corsair Force LE SSD & 1TB Western Digital Black HDD - Case: Corsair Carbide 300r - Lighting: 2 green Logisys LED sticks (currently removed)
There isn't one that makes sense this generation yet. 970 and 390 are both overkill, 380 and 960 are just a little too underpowered to reliably max out most games.
If you can get a 770 or a 280X get that.
