Fractal Design Define S
Solved by Prestonification,
Hi,
I am planning to move from my mATX CM Silencio 352 to an ATX Fractal Design Define S and I would like to know what you think of it?
Like if you have a better nice looking case for that approximate budget or else?
Thanks a lot
I don't have experience with your current case, but I wen't from a Windowed R4 to a S and am not even slightly disappointed. So much room and airflow with the only compromise being the amount of mechanical drives you can install which is 3. i give it a 4.5/5 right now.
