i am looking to buy gtx 980, but cannot determine if i should pay extra for non reference one. i am not overclocking it by myself, whatever it does in gpu boost is good enough for me.
I would suggest non refrence as they will to better in the long run and will let the card run cooler as well.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
you want none reference. i made the mistake of going with a reference 980ti and ill NEVER do that again. horrible cooling performance, loud card, and just overall shittyness. if your really concerned about colors i think linus has a vid on how to paint your components you can look up.
cost is not the issue, i can go as high as 600$, but if i am not overclocking it then that extra money i spent will be wasted. cheapest is 500$ .
Non reference.
On a side note, for 560 you can get a fury
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
