I ordered this and the warning came with it: http://www.amazon.com/dp/B0002GXF8Q/r
WARNING: This product contains chemicals known to the State of California to cause cancer and birth defects or other reproductive harm.
It is not a nut warmer. Don't chew it. Don't lick it. Keep it away from your dog. Keep it away from children.
However, I fail to see what you are asking.
https://linustechtips.com/topic/409649-prop-65-warning-label/#findComment-5517176
Please tell me you have common sense. The hell do you think that warning label is for? It's not food, it's not supposed to be consumed because of the materials. Duh.
Its fine to breath next to it? As long as I don't lick it or anything? Would washing it get rid of the chemicals?
https://linustechtips.com/topic/409649-prop-65-warning-label/#findComment-5517205
Yes
Yes
No
https://linustechtips.com/topic/409649-prop-65-warning-label/#findComment-5517249
What the warning says in normal language is DO NOT EAT.
Seems clear to me.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/409649-prop-65-warning-label/#findComment-5517374
