I'm just going to put this out there, you seem to have a lot of tech problems.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/408883-obs-problem/#findComment-5507784
Can't find it..
Help>Log File>Analyze Last Log File
Help>Open Log Folder
https://linustechtips.com/topic/408883-obs-problem/#findComment-5507851
Don't try to capture 1080p60
Disable "Multi-Threaded Optimizations" in the Advanced tab...its at the top
This error only occurs on Windows 7
Google is your friend
I can't even capture 1080p my monitor is 1050p 60FPS lol
And Thanks i will try that out!
https://linustechtips.com/topic/408883-obs-problem/#findComment-5508022
