New monitor, or additional monitor?
So I wanna change my monitor setup, the monitor I have is this > http://www.amazon.com/gp/product/B005BZNDOO?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s04
I plan on making a monitor stand like thing to put on my desk that I would keep my laptop under, and charge devices on. I plan on wall mounting whatever monitors I end with above my creation. The monitor I have is pretty small (21.5 inches). What I'm wondering is whether I should buy a whole new monitor (1440p maybe), or a matching monitor for the one I have. Of course, going with the second idea is a lot cheaper. (My monitors have to match or it would annoy me) Would it be worth it to buy a 27 inch better monitor, or just buy another matching one.
It really comes down to your use case, would you actually use the 2nd monitor in a multi monitor set up? Do you need it? If not then I would advise the 27" (1440p if you have the money)
For me I always found 27" to be the perfect size for a monitor (height wise) and if you go for 1440p you'll be able to fit more content into the screen from a productivity standpoint as well (If that was a reason you wanted duel monitor) You could also just keep your old one too, although ik you said them not being the same would annoy you.
You could get a 27" for not too much more than buying the same monitor you have again (Although you'd be looking at 1080p not 1440p) I would go for this one maybe
It's 27", and IPS for only $190
Or you can get a non IPS for about $20-30 less (at 27")
