Hello
I am currently looking at what SSD to get at the moment. I have heard that Samsung 850 SSDs have problems with them but I am not sure if they are sorted out now. What SSD would you choose for performance and reliability if money was not an issue.
Thanks
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
https://linustechtips.com/topic/406469-best-ssd-for-performance-and-reliability/
From my personal experience - corsair, but neutron is too slow. Try looking at the force gt series.
The Neutron has
Read 560MB/s, Write 540MB/s, 100k IOPS 90k
The Force GT is slower and they do not make a 1TB version
850 pro
It has the larger manufacturing process 3d nand which lasts a lot longer than normal SSDs
the 850 evo is the one that had those slowing down problems when data was not accessed frequently
the 850 pro uses MLC so that is not an issue
the other two SSDs are budget options and are rated for far less writes, they are also slower than both 850 drives
My Samsung 850 Evo's have been working a charm
As for like all out best, it has to be Intel 750's now, but obviously they are on another level, and so is their pricing.
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
850 pro
Thanks for that information.
So the 950 Pro did not have any problems, only the 850 EVO currently has these problems with it.
I will be getting one of them but I want a 1TB SSD as well
the 850 and 840 pro never had any issues
the 840 evo had the issue, it was "supposedly" fixed by a firmware update, but I still saw reports about it going on
then when the 850 evo was released I saw some people having the same issues with that drive
even if they didnt have those issues it is best to go with an MLC nand SSD, which is what the PRO version is :)
There are 1TB Evo's too o:
http://www.amazon.co.uk/Samsung-2-5-Inch-Solid-State-Drive/dp/B00P738MUU
I never really found justification to spend £100 more on the Pro version
I do not really want an SSD that has problems in my computer.
Crucial has the "highest" rated writes according to their in house testing for what that's worth for the reliability standpoint and also "enterprise level" data integrity features (caps for power loss, etc).  For me though I'd go Samsung Pro Series, might not have as high rated writes but compared to traditional hard disks the Pro meets or exceeds manufacturer rated writes.
All SSDs have had issues for some people, there is no major issue for the 850 Evo, there was for the 840 Evo at one point, but the 850 Evo has been fine.
Hello
Thanks
850 EVO has worked great for me over the past month. I got the 250gb version and I love it
Hello
Thanks
I use the Samsung 850 Pro. Fastest storage I've ever used and very reliable. It's the fastest SSD available on the consumer market that can properly be utilized.
I'm going to punch your face- IN THE FACE.
