Installing power supply (Witch screws should i use?) #FirstBuild
Solved by W-L,
Witch screws should i use to mount the power supply? I have the evga supernova 750 g2, and i have the corsair 750D (case)
In the manual for the power supply it says "use the screws from the case" and in the case manual there is no screws designed for power supply.
But maybe i can use some of the other screws, if they fit should i use them? The screws for HDD tray works perfectly
The 6-32 screws there should be some that came with the PSU or the same screws used to screw down the motherboard:
