Common ones are Prime95, Intel Burn Test, OCCT, 3DMark and such tools from Futuremark. I know Linus uses one specifically for GPU testing, cannot remember the name of it now, be he references it in a recent NCIX build video...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
I have used all of these and more: aida64 extreme (not free, but very good and I love it), prime95, occt, linx, cinebench, heaven benchmark, furmark and all futuremark 3dmarks.
Intel i5 3570k | MSI GTX 670 Power Edition/OC SLI | Asus Sabertooth Z77 | Corsair Vengeance LP 16GB | Fractal Design Newton R2 650W | NZXT Switch 810 SE Gun Metal | BenQ 24" XL2420T 120Hz | Corsair K90  | Logitech G500 / Logtitech Performance MX | Sennheiser PC 360 | Asus Xonar DGX | NVIDIA GeForce 3D Vision 2 Wireless Kit
CPU = Prime95
GPU = Kombustor
RAM = MemTest96+
Tantō
  • Case: NZXT Switch 810
  • Operating System: Windows 10 Professional
  • Motherboard: ASUS Sabertooth Z77
  • Central Processing Unit: Intel Ivy Bridge i7-3770K
  • Random-Access Memory: Corsair Vengeance 4x8 GB DDR3 1866 MHz
  • Graphics Processing Unit: Aorus GeForce 1080 Ti
  • Power Supply Unit: Corsair Professional Series AX750
  • Cooling: NZXT Kraken X52
  • Storage: AData S599 60GB + AData SU650 500GB + WDC Blue 1TB +AData SU800 1TB
  • Keyboard: CoolerMaster Masterkeys Pro S
  • Mouse: Corsair Scimitar Pro RGB + CoolerMaster Master RGB Hard Gaming Mousepad
  • Audio: Logitech 2.5 Speakers + Feenix Aria + Bose In-Ears
  • Monitors: 2x Acer Predator XB271HU
  • Thread Link
Shuko
  • Device Model: Samsung S20+
  • Operating System: Android 10
  • Read-Only Memory: One UI  2.1
  • Kernel: Stock
http://linustechtips.com/main/topic/1264-overclocking-guides/'>My Intel Ivy Bridge Overclocking Guide
Run Cinebench 10 times then AIDA64 (CPU, FPU, cache and memory tests, FPU is what makes the most heat so just run FPU if you're stressing your cooling) for a few hours to overnight. Then Heaven+3DMark for your video card needs. MemTest86+ is great, but that all depends if you like OCing RAM :P
Run Cinebench 10 times then AIDA64 (CPU' date=' FPU, cache and memory tests, FPU is what makes the most heat so just run FPU if you're stressing your cooling) for a few hours to overnight. Then Heaven+3DMark for your video card needs. MemTest86+ is great, but that all depends if you like OCing RAM :P [/quote']
MemTest86+ is great for anything RAM, not just to test overclocks...what if something shat on the RAM and you aren't OC'd? You'd have to test it anyways just like Linus did for his wifie's rig. Lol
Tantō
  • Thread Link
Shuko
  • Kernel: Stock
