Hey,
I got a set of 980ti's recently and it seems that they run super hot. When idling they are at 65C with 0-5% usage. What the f. I've got good case airflow with two 140mm fans blowing the cool air directly to the back of the cards (they are reference ones). Furthermore I've got 3x120mm fans blowing air on top of them. I've got two exhausts and a CPU on an AIO with heat going straight out from the case. When gaming the fans goes to 90%+ an the cards stay at 85C.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/403067-high-980ti-temps/
Reference cards are known to run extremely hot due to the poor cooling solutions on them.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434713
Dude 65C under no load in a room that's 25C ambient? Odd.
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434725
still dont you think thats abit too hot for idle? even them cards should only idle at around 35-40c.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434726
quote- NVIDIA GeForce GTX 980 Ti Idle Temps: At idle we found the GPU core temperature was 32C with the single fan on the NVIDIA reference cooler running at 22% or 1050 RPM. When gaming we hit 85C in a room with a temperature of 70F (21C), so nothing different from what you'd expect to see on high-end Maxwell GPU based cards
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434734
Peak temps are fine, but what is the fan speed at idle? might want to check the fan curve
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434735
Yeah but still, should be like low-mid 80's on load, and 100% shouldn't be 65 on idle!
I can only assume it's due to them being in SLI (You said you a set right?) That would raise the temps, but still seems a little high
I assume you've already checked something like gpuz to see what % the fans are spinning at load and at idle?
Other than that not sure what you could try :/
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434746
My reference ran at ~ 30c idle. Granted that was 1 card but 2 should never be that high. Something is definitely wrong.
Edit: make sure your fans are running.
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434751
just read a thread on another forum with people saying there evga 980tis idling at 62c, i wonder if its a heatpipe issue.
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434757
check the control panel and see what your power plan thing is at, also check on nvidia change them and then restart your computer
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434795
One card runs at 565Mhz and the other one runs at 1000Mhz? Wtf? Had a quick read on the interwebs and people report that they don't fully downlock and run very hot at idle..
Have a look:
https://forums.geforce.com/default/topic/841357/gtx-980-ti-issue/?offset=8
https://www.reddit.com/r/nvidia/comments/3a3fbl/sli_980ti_not_downclocking_idle_at_60c/
Any ideas on how to fix this?
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434805
Nothing wrong with those idle temps if you've got a card with fans that don't spin up unless there's excess heat or under load.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434822
Return them. It's not natural.
65 on Idle shouldn't be happening in any case.
INTEL Core i7-4790K  ASUS Maximus VII Ranger  CORSAIR Vengeance Pro 8GB 2133MHz  EVGA GeForce GTX 980 Ti  SAMSUNG 850 EVO 250GB  CORSAIR AX860i  CORSAIR Obsidian 750D
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434827
Coincidence that both run that hot? Don't think so.
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434845
Multi monitor perhaps? The ol' nvidia-doesn't-want-to-downclock-during-multi-screen-issue that's been arround since...forever.
Try downloading nvidia inspector and use the multi-display power saving option to force them to P8-P12. And also make sure the fans aren't 0% @ idle.
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434849
Have a look:
Do you have a high refresh rate monitor by any chance?
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5434856
It's prob that it's a 4k display, try to change res to 1080p or 1440p and see if temps go down
CPU: r7 5800x3D;  GPU: RTX 3090ti; RAM: 48GB DDR4; MoBo: ASUS CH VII HERO x470; PSU: Seasonic Prime 850 Titanium; Case: Be Quiet! Dark Base 900 PRO; SSD: Kingston 120 GB; HDD: 1x 500 GB 1x 2TB 1x 3TB;
My Anime List 300+ completed
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5435049
Okay, I've managed to figure out what was going on. The card were running so hot because they were not downclocking to the lowest speed. They should have been on 135Mhz but the top card was at 565Mhz and the second one on 1000Mhz- this was due to having "prefer maximum performance" in Nvidia control panel. After changing that do adaptive and doing a restart, they now hover at 135Mhz/145Mhz with 40C/33C :) I am a happy man now! This is the solution if you have the same problem.
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5435313
My Zotac 980Ti amp! extreme is 72° max in Firestrike and 65° max in witcher 3 with tweak ini ultrax2.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/403067-high-980ti-temps/#findComment-5436407
