so i was wondering if this is a problem but on my task manager i notice games and programs are 32bit (http://i.imgur.com/UR5SEt0.png) is this an issue or should i leave it the way it is?
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/402691-32-bit-programs-on-a-64-bit-system/
Totally not a problem at all. Most programs out there are written in 32 bit.
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
its fine
but if you have the option of a 64 bit program or a 32 bit
go with the 64bit
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
All 64bit OS are backwards compatible with 32bit software. Only problem is with drivers. Some 32bit drivers just refuse to even install on 64bit systems.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Unless it's something that's really memory-intensive or could benefit from certain 64-bit only features, running 32-bit apps on 64-bit systems is fine.
Examples of apps that might benefit from 64-bit are photo-editing apps, vector drawing apps, video editors and/or encoders, and web browsers under heavy usage. Generally speaking, anything that uses a lot of RAM could benefit from going 64-bit.
