Can I connect this 4pin fan to these 4pin/3pin connectors, even though it does not fit?
I only have a black, green, blue and yellow cable on my fan. Which one steps in as the red one?
Also, yellow fan cable to red floppy cable or the other way round?
Thank you all!!
PC fan colors are as follows:
3 pin fans are the same but without the PWM wire
2 pin fans are the same but without PWM or TACH wire
on a floppy drive,
Red +5v
black ground
black ground
yellow +12v
You want to ignore all of the fan wires except for ground and +12v
connect fan ground to floppy ground and fan +12v to floppy +12v to run at full speed
connect fan ground to floppy ground and fan +12v to floppy +5v to run at low speed
and its possible to get an intermediate speed:
connect fan ground to floppy +5V and fan +12v to floppy +12v to run at intermediate speed
If you want more fans, use longer paperclips and push them through the fan connector and out the top of it and then plug another fan onto it
This will not tell the motherboard fan speed nor will it let the motherboard control it.
Hope this helps!
