For some reason every core is running at 95-98% (3.5 stock) during gameplay and its taking a toll on my FPS (30 average). i'm playing the game maxed out (except AA) on 1440p but my 2 r9 280x's are only running at 40%. do i need to overclock my CPU or is it some sort of bug because this has never happened in any of my other games.
https://linustechtips.com/topic/401327-i5-4690k-gta-v-problem/
Is there anything else running?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/401327-i5-4690k-gta-v-problem/#findComment-5410751
oh hey you live in the same city as me, but no i'm only running msi afterburner to see cpu/gpu/mem usage
Probably a virus then. Run MBAM.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/401327-i5-4690k-gta-v-problem/#findComment-5410906
could be a rogue windows process.
you could narrow it down though, is there abnormally high cpu load at idle? if yes then it's something a miss, if no, it's a gta issue.
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/401327-i5-4690k-gta-v-problem/#findComment-5413993
Some settings are really CPU intensive. Set every setting to the lowest possible and then start turning them back up one by one. After you apply a setting check your CPU usage for big increases. That way you can find the CPU intensive settings and after testing every setting just turn those down a little.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/401327-i5-4690k-gta-v-problem/#findComment-5414041
