Revised Audio Setup
Go to solution Solved by johnt,
Let me clarify a few things for everyone here.
If you want surround sound from your computer, you need a receiver and an HDMI cable for audio. A sound card is not really going to help you. End of discussion. Can you use other connections? Sure. But you don't want to. There are many threads on this forum where I discuss the advantages of HDMI over other digital connections. But the fundamental fact is that you don't want surround sound from 3 to 4 different headphone jacks. That is an old school setup.
With that said, if you insist on using an old school setup, a dedicated sound card help improve the noise quality, but only if you have good speakers.
Guidelines:
Surround sound from a PC: Get a receiver
Reduced interference: Get a receiver
Headphones: Get a USB DAC
Surround headphones: They are typically USB anyway so no need for additional equipment
surround headphones is your argument let me go kill myself
Haha pretty dramatic  :) This is when you find another thread to troll
So I'm currently using a cheapy gaming headset that I got in a bundle (http://www.novatech.co.uk/products/peripherals/keyboards/gaming/ekm806regb-iu.html) plugged into my motherboard's (MSI Z97S SLI Krait Edition) on board sound. I think I would like a better aural experience, especially in video games.
From what I've read, the Kingston HyperX Cloud headset seems like a good shout. They're well priced at just £50 in my local hardware store, so I will probably go for those (unless someone has suggestion for a similar priced alternative). The thing I'm hesitant on is whether to get a sound card or not. I'm not sure how good the on board sound is on my motherboard (I've not tested enough to know the difference), so would a sound card be a good shout? Or is my on board audio good enough?
As a side note, I'd get a sound card over a DAC for aesthetic purposes. I know it's more prone to electrical interference, but DACs look a little sloppy just sort of sitting on the top of a case.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/401039-revised-audio-setup/
sound cards are absolutely useless. dac or onboard.
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406211
Is there any reason for this? Are they just inferior in terms of sound quality to DACs? Or does the interference really make that much difference?
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406252
they provide 0 or negative amount of benefits.
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406288
Not true, there great for more outputs and easy switching between said outputs.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406396
what do you mean more outputs? 7.1 and such?
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406409
Yeah, say you had a surround setup, and headphones and you wanted a port for 5.1, 7.1, and a port for you're headphones you could do that. That's the only benefit I can see from them, that's why I got a soundcard, of course I also upgraded to a new usb dac, but eh..
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406483
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406513
No, 7.1 isn't reserved just for headphones, it's for speaker's as well. Which is what I was trying to talk about, like this is a 7.1 home surround setup.
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406547
yeah so? if you have 7.1 speakers you can use front audio for headphones, if that sucks buy a dac.
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406571
Guidelines:
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406701
surround headphones though, seriously?
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406714
Guidelines:
Thanks for the help. I'll get myself a new headset and just stick to the on board audio, it's probably good enough.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406731
No problem. It's probably your best alternative. On board sound is a lot better these days than it used to be, so improvements with a dedicated sound card minimal for headphones.
I do recommend looking for USB headphones. They usually have a DAC and amplifier built in. The output is much cleaner than regular headphones and you don't get any of the analog hissing and cracking.
I hear ya, it's a weak argument, but don't raise your blood pressure over it. This forum exists to help put people on the right path. Marketing speaks multiples louder over reality.
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5406942
That's the opposite of what every audiophile believes.
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5410232
Uh, no. Most USB headphones are junk. A USB DAC and amplifier might be a good idea to combat such things, in certain situations.
https://linustechtips.com/topic/401039-revised-audio-setup/#findComment-5411472
