Ive used them in build and never had any issues, however I have had friends who will just rage when they see them in builds as they assume they just die.
Whats the general consensus on this?
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/399348-are-seagate-hdds-fine/
yeah, i like them.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/399348-are-seagate-hdds-fine/#findComment-5382089
Why wouldnt they be? Just as reliable as any other WD or Hitachi..
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/399348-are-seagate-hdds-fine/#findComment-5382095
They are perfectly fine and of course blackblaze did not properly test their drives and give proper sample sizes so it's a skewed result. It's been discussed before.
Edited by W-L
https://linustechtips.com/topic/399348-are-seagate-hdds-fine/#findComment-5382101
@terrytek
I personally prefer WD cause I've used them my whole life and they've been great.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/399348-are-seagate-hdds-fine/#findComment-5382102
They were used in the same enterprise environment as all the other non-enterprise drives, so the whole "not properly tested" excuse is just plain wrong. On a level playing field they did far worse than WD and HGST, so it makes sense to assume that they in fact ARE far worse.
As for proper sample sizes, if you have OVER FOUR THOUSAND drives of a particular model and around a third of those die within the first 3 years, that's a major issue.
The rest of the Seagate models also had a 6 to 10% failure rate, which is 3 to 5 times more than what the thousands of HGST (also non-enterprise) drives were doing in the same environment.
The current models seem to be doing better, but there's a lot of the slightly older rubbish ones in the stores still.
https://linustechtips.com/topic/399348-are-seagate-hdds-fine/#findComment-5382819
It's been discussed before the drives were used in poorly designed drive cages which are not for consumer drives. The main issue with sample size is the fact the drive were not the same drives throughout testing and not applied at the same time, some drives were internal storage drives others were taken from external hard drive and had their casing removed.
Note at 6-10% failure rate they would go bankrupt as said before also.
https://linustechtips.com/topic/399348-are-seagate-hdds-fine/#findComment-5382849
I honestly don't recall all the specifics, but if I remember right, one of the complaints
against Backblaze was indeed that there was actually not a level playing field. Not all
enclosures were the same, some were of a newer design, some of an older design, and the older
enclosures had a disproportionally high amount of Seagate drives in them. I think the main
difference between the two enclosures was the improved vibration dampening for drive protection
on the newer ones, which might actually make a significant difference for survival rates.
It's been a while since this has been last discussed, so I must admit I'm a bit hazy on the
details at this point. Also, I'm definitely no expert in statistics. However, as best as I
can tell, that would precisely be what is required in this situation. Somebody who properly
understands the whole statistics thing, and can adequately process the data so that we can
actually draw meaningful and realiable conclusions from it. As it stands, what we have
is merely raw data, and while I'm no statistics guru, I have among other things been taught
that drawing conclusions from raw data without proper care can lead to terribly incorrect
conclusions (it doesn't necessarily have to, but it can, or at least so I've been taught).
I fully agree with you that something smells fishy here with that high of a failure rate,
and it should be investigated. Maybe there was indeed something wrong with the drives,
but just going from the raw data without any additional info (What was the average load
on those drives? Load spikes, how frequent and how high? Average temperates? Temperature
spikes, how frequent and how high? Vibrations? I'm sure there's more) shouldn't be taken
as a be-all-end-all indicator of actual drive quality just like that. There are just way too
many unknown variables in play for such conclusions to be reliable.
I'm not saying field data cannot be useful and only data from a laboratory experiment
should be used to draw conclusions from, but when you do field experiments, you need to
document every possible environmental variable with utmost care and then take that into
account when drawing conclusions from your dataset (again, going by my admittedly very
basic knowledge on statistics). And as far as I know, that has not been done here.
That's what I make of the whole thing anyway. I honestly appreciate that Backblaze
release the data, but I take it with at least two grains of salt. ;)
EDIT: In the end, I'm not saying nothing went/is wrong here, I'm just saying that as
best as I can tell, we lack the information (all those unknown/undocumented variables)
to reliably draw the conclusion from that data that Seagate's drives are indeed horrible.
Backblaze basically didn't document their experiment properly enough for that, as far
as I can tell. If any expert on statistics ever comes across this, I would be very
interested in what they have to say. Maybe my conclusions are horribly misguided, but
with my limited knowledge on statistics, this is the best I can do, so to speak.
/EDIT
Also, this (see also quote below):
Lastly, this is my post from a thread about the Backblaze thing from a while back. It
compares the data with return rates from a large French online retailer (based on another
member's post, see link in quote), and things don't look too bad there, all HDD manufacturers
come out about the same:
- snip -
Anyway, I shall just post the link to a thread in which return rates for various hardware
components were given to a French hardware site by a French retailer.
The HDD section specifically (numbers in parentheses are numbers from previous dataset):
- Toshiba 1,15%
- Seagate 1,44% (vs 1,65%)
- Western 1,55% (vs 1,44%)
- Samsung 2,24% (vs 1,30%)
- Hitachi 2,40% (vs 3,45%)
Data is from 2013.
Link to thread: http://linustechtips.com/main/topic/108284-huge-list-of-failure-rates-on-pc-components-french-but-i-translated-nearly-everything/
Look at it this way: If there really was a serious problem with any one HDD manufacturer's
quality, they would long ago have lost all OEM contracts (just imagine Dell or HP buying
a few million drives and having a quarter of them fail, that HDD company would lose that
contract faster than they could say "lawsuit"), and since that's where the big money is,
they would have gone out of business sooner rather than later. Since that hasn't happened
so far, we can quite safely assume that for the most part there are no major faults with
any specific manufacturer. They might on occasion screw up, but by and large, there really
isn't that much of a difference between manufacturers these days.
Link to thread: http://linustechtips.com/main/topic/347320-who-makes-the-most-reliable-hard-drives/
EDIT 2:
This is not at all a properly documented experiment either, since it's many different
drives and many different users, but as a side note: In the 10 TB thread, we currently
have 1,110 drives, 366 of which are Seagate. We've had one or two users who have indeed
reported bad experiences with them, but we also have users who run tons of them without
issues. So far it doesn't seem like we come anywhere near an annual failure rate for them
of 10%~40% (depending on model, roughly the range reported by Backblaze).
Now, as said, this is not a properly documented experiment at all, however if Seagate
drives were indeed so horrible (i.e. if the conclusion that they are horrible were reliable),
I think I would expect more failures (then again, just because I expect something doesn't
mean it has to happen :D ). Of course not everyone will update their info and all that, so
who knows what's really happened, but I thought I'd add this for further pondering or
something like that.
Edited by alpenwasser
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/399348-are-seagate-hdds-fine/#findComment-5384054
