upgrade a pc without changing psu
Go to solution Solved by vchawda,
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
Motherboard: Asus MAXIMUS VII FORMULA ATX LGA1150 Motherboard  ($298.99 @ SuperBiiz)
Storage: Intel DC S3710 1.2TB 2.5" Solid State Drive  ($1799.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($657.89 @ Amazon)
Case: Corsair 750D ATX Full Tower Case  ($119.99 @ Newegg)
Optical Drive: LG BH16NS40 Blu-Ray/DVD/CD Writer  ($89.99 @ B&H)
Monitor: LG 24GM77 144Hz 24.0" Monitor  ($279.99 @ Newegg)
Total: $4028.67
Generated by PCPartPicker 2015-06-29 12:39 EDT-0400
Get something like this if you have zero budget, and ya wanna go all out gaming/deving.  Note this is a USD example, and stating get similar parts for your country.
i might go with this removing the liquid cooler and the hdd.
is the monitor g sync??
You should be fine with any gpu unless you are going to be running a 390X overclocked + a FX9590.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
i have a corsair vs650 power supply and i want to upgrade my pc to the fullest (singel gpu) purely gamming and coding in different languages.
If you have a single GPU then that PSU should provide enough power.
Get a 980 Ti
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
my current specs are:
AMD FX-4100
Gigabyte GA-880GM usb3
8GB ddr3 ram
Cooler master hyperx 212x
1 blue edition WD 250GB hdd
1 1TB green WD hdd
Yep that setup would be fine with any modern gpu, I would reccomend a 280/380 or a 960.
AMD FX-4100
8GB ddr3 ram
1 1TB green WD hdd
i'm sorry to any amd fanboys, but however you turn it, that cpu paired with any "fastest single gpu" is a plain joke.
as stated before, R9 280/380 or GTX 960 would be in place here.
AMD FX-4100
8GB ddr3 ram
1 1TB green WD hdd
So currently you have no GPU?
Echelon Mk 2.11
Exactly
Where is your location? How much is your budget?
Echelon Mk 2.11
That is one of the slowest FX chips if not the slowest.  On top of that it could be sped up with DX12 via better utilization, but they'd be better off with a pentium, i3, or i5 for gaming with DX11.
on that note, i was just looking at quad cores for my server, and AMD makes much MUCH worse than that...
(also for much MUCH cheaper, YAY budget option...)
i live in mumbai in india
there is no bar for budget i have an investor who is gona pay me
So you want the latest and most expensive components? Or the best price to performance option?
Echelon Mk 2.11
That 8GB of DDR3 is still fine, I recommend hanging on to those along with your storage drives and CPU cooler as well.
I'd recommend a new motherboard, new processor and a new video card. What is your budget?
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
there is no budget limit as i mentioned earlier
Ya, AMD hasn't done much since '12 with the opterons.  A lot of the new ones are lower end.  They haven't put out a strong 16 core in like 3 years.  Everyone swapped to Xeons and IBM or whatever Oracle pushes.
i'm really sad that i didnt get to tinker with the spark servers we had in high school.
if they performed after their weight, they'd crush everything -bahdumtish-
but indeed, the cpu side of AMD has gotten really sad, i liked my athlon 64 based server (which was REALLY FLIPPIN FAST for its age)
but sadly, theres a point where old hardware fills the room with smoke, and its time for an upgrade. running two intels now.
on topic:
- hang on to the ram, because ram is ram, and if it works you might as well re-use it.
- the PSU is good, on less energy gulping cards it could even do SLI.
- NEVER throw away working hard drives, as long as they do their job, keep on using them. i have a system with a 20 year old hard drive thats still going strong.
- hang on to the case, maybe for a side project, maybe for the cat (my cat loves sitting in a computer case, but hates cardboard boxes...)
actually, while i'm typing this: might as well hang on to all the hardware you're using now for a future server build, or for a linux system. (since you're programming, this may also be kinda your area of interest)
I kinda went a lil insane above for their "0/zip/nadda budget" for extreme gaming and deving.  xD   Also, hopefully AMD comes back with Zen as right now it is all talk.  :/
as an intel/nvidia fanboy, i'm actually hoping zen will completely CRUSH intel's single threaded performance.
also, why not 32GB ram? i know some devs that would make good use of that :P
i prefer price to performance also suggest a full hd monitor.
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($82.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($99.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($329.99 @ SuperBiiz)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Total: $1025.78
Generated by PCPartPicker 2015-06-29 13:25 EDT-0400
I don't have extensive knowledge about monitors, I suggest posting at the monitors sub-forum on this forums.
Echelon Mk 2.11
