Overclocking console replacement.
Go to solution Solved by Prysin,
@Faceman
What is the point of forcing something down someones throat if they are not specifically looking for it heh?
OP of this thread specifically said OVERCLOCKING. So when it comes to OVERCLOCKING, you cannot do that on a i3. IT IS NOT GOING TO HAPPEN. Now the 860k for all intents and purposes perform admirably given its price. The G3258 is great, it also, for the time being, have an upgrade path. It also only have 2 threads. Which in some games are no problem, and in others IS. Because some games simply doesnt let it run the game due to lack of threads.
The last few days I've been doing research for the above stated build, with 3 cpu/apu's in mind- G3258, X4 860K, and A10-7850K. I know the X4 and A10 are more or less the same chip with or without the igpu. Much of the information I've found on here is they will all bottleneck as soon as the processor has a decent load put on it, framerate stutters and that they will bottleneck a GTX 960. All of this seems contradictory when many review videos praise the cpu's for their price to proformance. What I would like to know is how likely is it any of the issues will happen and to what extent?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor
Motherboard: Gigabyte GA-Z97M-DS3H Micro ATX LGA1150 Motherboard
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor / A10-7850K
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Gigabyte GeForce GTX 960 2GB Video Card
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply
i5-4690K, Gigabyte Z97X-SLI, GTX 960 Gaming 4G, HyperX Fury 8Gb 1600Mhz, Corsair Spec-01
https://linustechtips.com/topic/395866-overclocking-console-replacement/
i3-4150/4160 and a cheap B85 board will perform better than any of those solutions OP.
With the prices right now it would be this:
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor ($108.95 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-GAMING 3 Micro ATX LGA1150 Motherboard ($44.45 @ OutletPC)
Total: $153.40
Generated by PCPartPicker 2015-06-28 13:33 EDT-0400
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
I would go with the Athlon. Neither of those CPUs will bottleneck a 960, my OC pentium doesn't bottleneck a 280 which is the same level as a 960
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
Overclocking is a requirement.
why so? i'm telling you: this little core i3 perform better in games than a 5ghz G3258 or a 5ghz 860K...hands down. (i tested all this please refer to my youtube videos if you want to know more)
It shouldn't be when you can get much better performance out of an i3 processor that doesn't need to be overclocked.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
This is going to be my first OC build and is going to be more or less a learning build
Thats fine and all, but that doesn't mean you should purposely handicap your performance just so that you can overclock.
in that case, i would go with the G3258, that way at least you'll have a good motherboard once you realise you want a real processor you'll be able to drop in an i5-4690K or i7-4790K without having to buy a new motherboard again.
you'll see...games are a stuttery mess with this dual thread CPU, you need 4 threads minimum for games, the athlon isnt really better cause the cores are just so damn slow...none of these will be a good match for a GTX 960...you'll get full performance on a GTX960 with a core i3 CPU or better.
I'm not worried about handicapping this build as this isn't my desktop. in 3 month I'm going to building this or a Skylake equivalent.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  ($74.99 @ Mwave)
Motherboard: Asus Z97 PRO GAMER ATX LGA1150 Motherboard  ($163.98 @ Newegg)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  ($99.99 @ Newegg)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive  ($55.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ Newegg)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($329.99 @ Amazon)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: BitFenix Fury 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($109.99 @ Mwave)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($86.98 @ OutletPC)
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm  Fan  ($20.85 @ OutletPC)
Monitor: Acer GN246HL 144Hz 24.0" Monitor  ($189.99 @ Newegg)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($81.99 @ Amazon)
Total: $1663.56
Generated by PCPartPicker 2015-06-28 13:44 EDT-0400
Then why even both with this build?  Or if you are planning to upgrade to an i7-4790k in just a few months, that makes it a no-brainer to go with a Pentium G3258 + Z97 motherboard.
The 4790K is going to be  my desktop when its built. The G3258/X4 860K is a console replacement media PC. I'm building both, the media pc has higher priority atm
a media PC should be quiet...idealy silent, and this won't go hand in hand with overclocking...build yourself a small form factor machine around a core i3 CPU and a GTX 960. This will play, run and render just about anything very well.
If y
Total: $1663.56
Buy a good intel mobo if you are doing an I7 build in a few months, no point of going AMD just to have to change it 3 months
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
Oh, for a media PC I'd go with AMD, it's cheaper and it doesn't require that much CPU performance anyway
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
And...If you are getting a 960, dont get an APU, save money on integrated graphics you are not gonna use anyway
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
If i was to build myself a media pc for my living room, i would go with this with the prices and deals available as of today:
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($48.99 @ Newegg)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($80.00 @ Newegg)
Video Card: EVGA GeForce GTX 960 2GB Superclocked Video Card  ($184.99 @ NCIX US)
Case: BitFenix Aegis Core (White) MicroATX Mid Tower Case  ($69.99 @ NCIX US)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ NCIX US)
Total: $645.35
Generated by PCPartPicker 2015-06-28 14:03 EDT-0400
This is powerful, yet cheap...reliable and also very quiet (i would add a small and cheap aftermarket heatsink for quieter operations as well if possible.)
Total: $645.35
The i3 is out of the picture since it doesnt OC. The whole point is to learn to OC on the media PC so when time comes I know what i'm doing on the desktop.
thats rediculous...OCing nowadays is as easy as up the CPU multiplier a couple notch, add some more volts to vcore, test for stability, rince and repeat...you don't need or have to build a machine to learn something that can be done in a matter of an hour with an overclocking tutorial..it's ridiculous.
You can also make your hand on the core i3 machine, learn to lower the voltage on your CPU...make it more efficient, undervolt it...or overclock it on the FSB...you can get the strap to run at 103 or 104mhz...there's all those settings you can tweak, your RAM, cpu VCCIN etc. all of that you still get you can mess with the bios all you want...the only thing you can't do is change the CPU multiplier...all the rest you can still do.
This would be the recommendation for a cheap overclockeable rig that you could tweak all you want so long as you don't care much about running modern AAA titles:
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler  ($19.99 @ Best Buy)
Motherboard: ASRock Z97M Anniversary Micro ATX LGA1150 Motherboard  ($74.99 @ Newegg)
Total: $651.82
Generated by PCPartPicker 2015-06-28 14:14 EDT-0400
Exactly as nanosuits said.  Go with an i3 + 960.  In just 3 months time you will be overclocking your i7.  There is no need to buy a sub-par processor and overclock it when you can buy a much better processor that doesn't need to be overclocked.
According to benchmarks made by anandtech, for mid ranged cards, the A10 and Athlon 860k can keep producing framerates and performance around that of an midrange i3. Nothing more. The i3 would in general be a better buy, but if you want to OC then 860k is a better choice then the pentium due to its extra threads, The pentium sometimes get locked out of games due to lack of threads.
he wants to learn overclocking haswell...which is somewhat different than FM2+ from AMD...i know principles are the same, but the settings in the bios varies a lot...just saying.
BTW OP, here's a very good overclocking guide on haswell...very thoroughly put together by a good friend @ProKoN, experienced overclocker here on the forum:
http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
You can overclock your 4790K (or g3258, i5-4670k/4690k whatever) in a matter of an hour or so with this tutorial...then you test the settings you think are stable for like a week, and then you improve upon until you get to know your chip very well...everything you might want to know is in there.
I have to agree that FM2+ OCing is hard, ive set up two 7850k systems, and getting these things stable while balancing temps and voltages arent easy. But it makes for a good feeling when you get it right.
