Desktop Hard Drive for ps4
Solved by asker509,
I thought you couldn't use a external hard driveJust buy an external hard drive rather than looking to change the in built one,. If you really have to. its 9.5mm and can be found in ebay or amazon. replacing it is also easy with just a screwdriver.
anyway my current hard drive is so I'm just gonna replace it
I already bought the Toshiba and the nyko data bank
Featured Topics
Louscou ·
Posted in Troubleshooting0 -
1
nulcow ·
Posted in Laptops and Pre-Built Systems2 -
2
1
SteffanF ·
Posted in New Builds and Planning3 -
2
HyperPalBuddy ·
Posted in Audio0 -
1
wyndwalker ·
Posted in Power Supplies2
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
