One of my guitar strings broke (I haven't changed them since I bought it, so I think they are around 8 years old), so can you suggest me a decent brand, but not too expensive.
http://www.amazon.it/s/ref=sr_nr_p_76_0?fst=as%3Aoff&rh=n%3A3628629031%2Cn%3A5021798031%2Cn%3A5021857031%2Cn%3A5022094031%2Ck%3Acorde+chitarra+elettrica%2Cp_76%3A490210031&keywords=corde+chitarra+elettrica&ie=UTF8&qid=1435242544&rnid=490209031
https://linustechtips.com/topic/393774-electric-guitar-strings/
We're a tech forum, questions like this are better at places like this:
http://www.ultimate-guitar.com/forum/forumdisplay.php?f=26
http://www.guitars.co.uk/forum/electric-guitar-forum
There's plenty of guitarists here dude..
@-TesseracT-
https://linustechtips.com/topic/393774-electric-guitar-strings/#findComment-5313948
@-TesseracT-
Sure, there's probably a few builders and tradesmen on the forum, but the questions are unrelated to what the forum is for, and will generally get better, more informed answers if asked in a place dedicated to that subject.
https://linustechtips.com/topic/393774-electric-guitar-strings/#findComment-5313961
Do you understand what this sub-forum is for? :mellow: And just the sheer number of people that play guitar?
https://linustechtips.com/topic/393774-electric-guitar-strings/#findComment-5313982
I understand your point, but note the subforum this is in :P
EDIT: Ninja'd by @AlwaysFSX
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/393774-electric-guitar-strings/#findComment-5313984
I'm not saying he can't post it, just that other places would be a better option, as it's dedicated to it. Much like asking a question about a graphics card on a guitar forum. You can do it, sure, but posting it here would be better.
Also, even in off-topic, it's still primarily a tech forum
At all times though, this is a tech centered and focused forum.
http://linustechtips.com/main/topic/234698-posting-guidelines-please-read/
https://linustechtips.com/topic/393774-electric-guitar-strings/#findComment-5314015
It's electric, it uses tech! Plus, who bothers signing up for other things? I mean.. that's work.
https://linustechtips.com/topic/393774-electric-guitar-strings/#findComment-5314030
Ah, work, the fear of most PC enthusiasts xD
Anyway, @OP if the guitar is 8 years old, even the cheapest strings will be better than the current ones. I'd personally go for the next to cheapest, or lower-mid priced ones, it's normally your best bet in terms of value.
https://linustechtips.com/topic/393774-electric-guitar-strings/#findComment-5314057
8 year old strings?? My goodness... I'm surprised they didn't corrode away! In all seriousness, I always use Ernie Ball 11's when I gig and record. They're $6ish a pack and last a good while without corroding or getting all slimey.
CPU: Ryzen R7 1700X Motherboard: ASRock X370 Gaming K4 CPU Cooler: Corsair H60 RAM: Crucial 32GB 12400Mhz GPU: Zotac GTX 1080 AMP! Edition
SSD: PNY 240GB HDD: Toshiba 3TB 7200RPM PSU: EVGA 1000 GQ Case: NZXT S340 Display: Dell P2416D
Camera: Samsung NX1 Audio: Tascam DR-40 Mic: Rode NTG2
Interface: Focusrite 18i20 Monitors: Event 20/20's Mic: Blue Bluebird DAW: Steinberg's Cubase 7.5, Adobe Audition CC
Guitar: MIM Fender Stratocaster Amp: Peavey Classic Chorus 212 Pedals: Dunlop High Gain Volume, Big Muff Germanium Pi, Boss DD-3 Delay, Roland Tuner
https://linustechtips.com/topic/393774-electric-guitar-strings/#findComment-5315290
