Would it be worth going all out for like a NZXT HUE or something as I need brightness as I bought a cheap LED kit for £1 and it looks disgustingly terrible.
Also should I just go for white even though I have a Black and Red build?
Thanks
https://linustechtips.com/topic/393471-good-led-kit/
Pics?
http://linustechtips.com/main/topic/333300-build-for-a-friend-of-a-friend-who-became-my-friend-pics/
its smoother irl
I think this is on the lowest setting
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5309573
NZXT Huehuehuehue
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5311084
SNIP
http://www.scan.co.uk/products/akasa-ak-ld02-05wh-vegas-led-strip-light-60cm-white
I use these, they are really nice, the adhesive is wank though
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5312157
Our LEDs are simple, you pick what you want. I will then make it, and send it right to your door. All you do is open package, peel off the sticky back, stick you where you want them, plug in the strip and turn on your computer.
 You can pick the power cable length (10cm to 2 meters) Sleeving Colour (Black, or Red) and choose either a 3pin fan connector or 4pin molex.
We ship worldwide, we are UK based as you are in Belfast shipping will only be £1.
Reviews of our Products
LTT Member Lays done a quick review here - Click Here
LTT Member jtai117's review can be found here  - Click Here
Richard @ Designs By Richard  took some really nice photos you can find them here - http://imgur.com/a/qwNDB
You can see our LEDs on our store, AddonCustoms.com
Are you looking for RGB (where you can change the colour with a remote control) or a Single colour strip?
Our RGB lighting will be available soon, its currently being tested to make sure it all works before we add it to our store.
Feel free to PM me on here and we can discuss this more.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5312171
SNIP
Not sure at the moment but I can't believe I forgot you guys!
I will check you out right now!
Also, do you have any pictures of red to see what it looks like?
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5312588
:D
Please forgive the boring black and white store style, I am working on a new design that is far better. :)
Addon Customs -
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5312596
Thanks
White leds go with anything. But . . . I have white and sometimes i want color. I bought a cheapo 5 dollar set, so If i had a choice again I'd say go with the hue.
Don't Drop the Soap
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5321176
Yeah I feel like during the day I want red and night I want white.
Only thing I'm worried about is my optical drive tray being in the other chamber maybe losing a bit of length.
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5321869
If you put it in the bay closest to the windowed side panel you should be fine. If it didn't fit, which I doubt (since it's designed to fit in full towers) you could use Luke's ghetto drive bayless solution.
Don't Drop the Soap
https://linustechtips.com/topic/393471-good-led-kit/#findComment-5324711
