Well, it's not really needed. It just means you don't have to keep grounding yourself when you're working. Both old and new electronics are vulnerable to static discharge. If you ground yourself by touching something metal every now and again when working, you should be fine. Just don't work on carpet or in a fluffy jumper or anything.
https://linustechtips.com/topic/392993-anti-static-wrist-strap/#findComment-5303446
Hello,
I have an old PC that is very dusty and i would like to remove some parts to clean them. I would assume that an anti-static wrist strap is needed because I'm still dealing with electronics. Or do you only need it when dealing with new hardware?
Thanks
its a good idea, to be cheap and safe touch the psu with it plugged in but off (0) that will ground you. Honestly most of use probably don't use them or ground ourselfs with little incident
https://linustechtips.com/topic/392993-anti-static-wrist-strap/#findComment-5303448
Only ground yourself if the electronics are also grounded, you want to be at the same electrical level (potential difference) as the components .  NOT grounded whenthey are not.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/392993-anti-static-wrist-strap/#findComment-5303472
Thank you everyone for your replies. I think i might buy one to be safe. Its only $3
for the sake of them costing almost no money and easy to wear its probably worth the precaution
I am sure we all have stories, I mean I worked on maybe 50 pcs myself and loads in my old job, never wore a static wrist band once and no incidents.. but it only takes one jolt to fuck up your stuff
https://linustechtips.com/topic/392993-anti-static-wrist-strap/#findComment-5303564
The metal itself also have to be grounded, Like the ground pin in the socket or a copper or aluminium pipe into the ground.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/392993-anti-static-wrist-strap/#findComment-5303598
Never used one, just don't be on carpets or around pets or other things that could build up a static charge.
Useful threads: Code of Conduct || Unofficial LTT Beginners Guide || Forum FAQ
CPU: Intel Core i5 4440 GPU: GTX 760 MOBO: Asrock Z97 Anniversary RAM: 8GB Adata @ 1600 Mhz Case: Define R4 SSD: Kingston V300 128 GB
HDD: 1TB Seagate Barracuda NAS: 3TB Seagate Barracudas in RAID 1 PSU: EVGA 600B (600W 80+ Bronze) Display: LG 23MP75 (1080p IPS @ 60hz)
https://linustechtips.com/topic/392993-anti-static-wrist-strap/#findComment-5305842
Try getting a wireless one
The weird kid in the corner eating glue
“People think that I must be a very strange person. This is not correct. I have the heart of a small boy. It is in a glass jar on my desk.” - Stephen King
https://linustechtips.com/topic/392993-anti-static-wrist-strap/#findComment-5305855
