BSOD when installing stuf? + CPU FAN error
Go to solution Solved by YoYo155,
The dump indicates a 4.251GHz @ 1.21v overclock.
Please revert back to default in-order to receive further help otherwise it's a wast of time.
5: kd> !cpuinfo
CP F/M/S Manufacturer MHz PRCB Signature MSR 8B Signature Features
5 6,60,3 GenuineIntel 4251 0000000700000000 21193ffe
Cached Update Signature 0000000700000000
Initial Update Signature 0000000700000000
5: kd> !sysinfo machineid
Machine ID Information [From Smbios 2.7, DMIVersion 39, Size=3189]
BiosMajorRelease = 4
BiosMinorRelease = 6
BiosVendor = American Megatrends Inc.
BiosVersion = 0903
BiosReleaseDate = 05/06/2013
SystemManufacturer = ASUS
SystemProductName = All Series
SystemFamily = ASUS MB
SystemVersion = System Version
SystemSKU = All
BaseBoardManufacturer = ASUSTeK COMPUTER INC.
BaseBoardProduct = Z87-PRO
BaseBoardVersion = Rev 1.xx
5: kd> !sysinfo cpuinfo
[CPU Information]
~MHz = REG_DWORD 4251
Component Information = REG_BINARY 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Configuration Data = REG_FULL_RESOURCE_DESCRIPTOR ff,ff,ff,ff,ff,ff,ff,ff,0,0,0,0,0,0,0,0
Identifier = REG_SZ Intel64 Family 6 Model 60 Stepping 3
ProcessorNameString = REG_SZ Intel® Core i7-4770K CPU @ 3.50GHz
Update Signature = REG_BINARY 0,0,0,0,7,0,0,0
Update Status = REG_DWORD 2
VendorIdentifier = REG_SZ GenuineIntel
MSR8B = REG_QWORD 700000000
Processor may be overclocked!
Expected Frequency: 3500
Actual Frequency: 4251
Overclock Ratio: 1.21
Other then that make sure your PSU is Haswell compatible and that you have adequate cooling.
I keep getting Randomly BSOD, i think it happends when i install programs on my pc.
Also when i turn on the PC i get a Error that the CPU fan is not connected. when it cleary is spinning and connected like it should.
I Builded this PC yesterday and i had a few problems but it works now ( i think :P)
Dump files: http://www.mediafire.com/?ev757xag25d40et
https://linustechtips.com/topic/38985-bsod-when-installing-stuf-cpu-fan-error/
Overclocked??
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
Did you do any overclocks and and is the CPU fan plugged into the CPU fan header?
No, i dident do any overclocks. im also using regular CPU fan that you get when you buy i7 4770k.
and im sure it is connected to CPU FAN header. it says so under it on the MOBO
Ok.
Have you changed any boot or sata options in the bios?
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
BTW: im running this
Windows 7 ultimate
i7 4770k
z87-pro
Gainward gtx 770
silerstone 750 PSU
Seagate barracuda 1tb
Corsair Vengeance DDR3 1600MHz 8GB
A Samsung CD reader
Can't you just permanently change boot order in bios?
Specs: CPU: i5 3570k @4.5Ghz CPUcooler: Corsair H80 RAM: 16GB Corsair Vengeance @1833Mhz MOBO: MSI Z77A-GD65 GPU: MSI Geforce GTX 670 PE OC PSU: Corsair TX850 FANS: 5x Noctua NF-F12 CASE: Fractal Design Define R4 Windowed with Adjust 108 Fan Controller
Have you tried all the usual stuff, drivers and such. Because it's a new build are you sure you have all the necessary drivers? Or the right drivers?
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
i did, but Because of the CPU fan error i always have to go in BIOS and boot with HDD.
I see. Are you're temps okay?
i updated almost everything, in windows update there are 4 important updates that wont install. i just get a error every time i try
i just Ran Prime95 and the CPU temps when to 72 degrees celsius and then the pc froze and gave me the BSOD
What are the updates, can you see what they are before installing them. Also, on the last generation of intel processors the maximum recommended temperatures were 67 excluding anything higher than a 3770k.... However you don't really start seeing BSOD problems until 90 degrees
Is it just the low RPM monitor? You can overcome that by going into the BIOS -> Monitor -> 'CPU Fan Speed Low Limit' and set it to a lower RPM or simply to ignore.
Not sure why the Intel cooler would trigger that though, normally only on aftermarket solutions...
As for the windows updates, I've found that sometimes doing them individually helps.
There's something wrong with your CPU cache according to all 4 of the dump files you uploaded. As it's new RMA it, I would say it's a dud.
Windbg report
WHEA_UNCORRECTABLE_ERROR (124)A fatal hardware error has occurred. Parameter 1 identifies the type of errorsource that reported the error. Parameter 2 holds the address of theWHEA_ERROR_RECORD structure that describes the error conditon.Arguments:Arg1: 0000000000000000, Machine Check ExceptionArg2: fffffa8008203028, Address of the WHEA_ERROR_RECORD structure.Arg3: 00000000ff800000, High order 32-bits of the MCi_STATUS value.Arg4: 0000000000000124, Low order 32-bits of the MCi_STATUS value.Debugging Details:------------------BUGCHECK_STR:  0x124_GenuineIntelCUSTOMER_CRASH_COUNT:  1DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULTPROCESS_NAME:  WinSAT.exeCURRENT_IRQL:  fSTACK_TEXT:  fffff880`009bbb58 fffff800`031faa3b : 00000000`00000124 00000000`00000000 fffffa80`08203028 00000000`ff800000 : nt!KeBugCheckExfffff880`009bbb60 fffff800`02d8e443 : 00000000`00000001 fffffa80`0820aa60 00000000`00000000 fffffa80`0820aab0 : hal!HalBugCheckSystem+0x1e3fffff880`009bbba0 fffff800`031fa700 : 00000000`00000728 fffffa80`0820aa60 fffff880`009bbf30 fffff880`009bbf00 : nt!WheaReportHwError+0x263fffff880`009bbc00 fffff800`031fa052 : fffffa80`0820aa60 fffff880`009bbf30 fffffa80`0820aa60 00000000`00000000 : hal!HalpMcaReportError+0x4cfffff880`009bbd50 fffff800`031f9f0d : 00000000`00000008 00000000`00000001 fffff880`009bbfb0 00000000`00000000 : hal!HalpMceHandler+0x9efffff880`009bbd90 fffff800`031ede88 : 00000000`00000000 fffffa80`08fe2680 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55fffff880`009bbdc0 fffff800`02c764ec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40fffff880`009bbdf0 fffff800`02c76353 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6cfffff880`009bbf30 fffff880`05340a23 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153fffff880`06e330f0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgmms1!VIDMM_GLOBAL::ReferenceDmaBuffer+0x9afSTACK_COMMAND:  kbFOLLOWUP_NAME:  MachineOwnerMODULE_NAME: hardwareIMAGE_NAME:  hardwareDEBUG_FLR_IMAGE_TIMESTAMP:  0FAILURE_BUCKET_ID:  X64_0x124_GenuineIntel_PROCESSOR_CACHEBUCKET_ID:  X64_0x124_GenuineIntel_PROCESSOR_CACHEFollowup: MachineOwner
HTTP/2 203
Windbg report
Could you explain it a little more? and mayby how to fix :S?
Fixed the fan problem not everything works Smooth but the BSOD....
I googled the 'Failure_Bucket_ID' and it came back with this thread, http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/windows-experience-index-bsod-at-run-assessment/7bc68967-cc7e-4a8a-a6be-23c17aa8bf6d, perhaps pepsimaxl could try a BIOS update since that fixed it for them. Might be worth a shot, since RMA'ing the CPU straight away is a rather drastic IMO.
How did you do it? Or was it the solution I posted?
i had my fan connector in CPU_FAN_Opt
so i switched it to the CPU_FAN and it worked
also can you help me find drivers for my MOBO z87-pro
Yup, there is a BIOS update available for your board. V1205. Give that a go first, if you need a hand/instructions for updating the BIOS on a EUFI Asus board gimmie a shout.
Said update and the rest of the drivers are available from here. http://www.asus.com/Motherboards/Z87PRO/#support_Download_30, I'm guessing you're on 7 x64.
I would recommend getting your drivers (excluding graphics) using a program called 'Driver Genius' as the ones on Asus's site normally aren't the latest. There may be other programs that's just the one I use.
Tom
5: kd> !cpuinfo
BiosVersion = 0903
SystemSKU = All
[CPU Information]
Ah if it's overclocked, put it back to stock before you start complaining about BSODs. And as I said in my previous post, if it remains broken after reverting to stock, your CPU's probably dud, so RMA it. It's entirely possible it was damaged in shipping/manufacture or never worked at all (bad dye etc).
HTTP/2 203
Stupid me! when i was installing my CPU i acidently hit the TPU switch, and the board was set to Extreme overlclock ....
i switched it back and it works perfectly :D!
Thanks for all your help guys! love ya all!!
Glad I could help.
Your avatar just got a whole lot more real....
I was thinking just that.
