BF4 low FPS?
Go to solution Solved by xAcid9,
no, people are saying that it's bad and dead
Use it bro, and lower your overclock a little since Mantle tend to stress your card to the limit.
Okay i been playing few maps 64 player, now on map called Operation locker i get 55-60 FPS (Vsync on) and now a MAP Siege Of Shanghai i get shitty 30-37 FPS (Vsync on)
Specs: MSI R9 280X (Clocked 1170, but i will push it more), I3 4150, 8 GB of RAM.
I would like to have at least 45 FPS
My drivers Version: 9.14.10.01080, Catalyst 14.1
EDIT: Game settings: High
https://linustechtips.com/topic/387160-bf4-low-fps/
Doesnt seem right.. what settings are you using? turn your settings down, should easily be getting 60fps
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224646
I forgot to mention that High
Turn off AA? turn down post processing to low and stuff - even on my 780ti I have a few settings on low/medium to get a smooth 60fps at 1440p - I have textures on HIGH, AA at 2x and everything on LOW (Mesh on ULTRA)
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224674
Are you using Mantle?
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224683
I tired that, I get like 90 FPS and it goes down to 30FPS
Hmmm, shouldn't be fluctuating that much.
Try changing the settings to medium or low, with V-syn off and anti-aliasing off, and see if it still fluctuates that much. Shouldn't be any bottlenecks with your specs though, temps good?
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224693
Are you using AA?
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224716
I think Siege Of Shanghai still has a few problems to do with performance.
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224723
Turn your settings down.  BF4 is extremely CPU heavy, and having a dual core w/ HT isn't helping.  Source: I get the same problems with my laptop.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224796
BF4 runs like utter crap if you use Windows 7. That's just how it is, it needs so many CPU resources (especially on some specific maps and in 64 player servers) that it just craps itself on anything lower than a 6-core i7. With windows 8.1 it runs a bit better due to DirectX 11.1 and because 8.1 is a bit more lightweight.
Try to reduce mesh and effects quality to low, that should help a bit.
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224818
there is no aa only mass or something like that
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224894
lolwat
What kind of retards are saying that?
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224920
Mantle works just fine, it really helps for my setup and should be ideal for you with a fairly weak CPU.
There is post processing AA (which you should turn off because it looks terrible), MSAA (which takes a huge amount of performance, 2x maximum, I wouldn't go any higher) and then you can also turn up the rendering resolution up to 200% (which is effectively 4xSSAA).
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224923
There is no AA in settings
yes there is, there is MSAA and there is post processing AA
mHu6Fsu.jpg?1
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224946
https://linustechtips.com/topic/387160-bf4-low-fps/#findComment-5224983
