Okay, so I am going to switch from a wireless connection for my PC to a wired one, and I need help. I already did the measurements, I need a 150 ft cable. So, my two questions are, which CAT type should I use, (ie 5, 5e, 6, 7, etc...), and should I go shielded or unshielded. And yes, I need a 150 ft cable because I'm not allowed to drill a hole through the downstairs office to my computer, which is in my room upstairs, so no, I can't get a shorter cable. I wish I could. Thanks in advance!
https://linustechtips.com/topic/386248-ethernet-cable-help/
I'm pretty sure most people run just Cat 5e, but I'm no IT guy, so don't take my word for it. I'm using monoprice Cat 5e and I get absolutely no slowdown in network speed. (50-55 down, 8-10 up)
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5213480
Okay, so I am going to switch from a wireless connection for my PC to a wired one, and I need help. I already did the measurements, I need a 150 ft cable. So, my two questions are, which CAT type should I use, (ie 5, 5e, 6, 7, etc...), and should I go shielded of unshielded. And yes, I need a 150 ft cable because I'm not allowed to drill a hole through the downstairs office to my computer, which is in my room upstairs, so no, I can't get a shorter cable. I wish I could. Thanks in advance!
CAT 5e should be good since it's within it's 100m (328ft) limit for gigabit connections.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5213487
The standards for Cat 5e and Cat 6 call for a maximum run length of 90 meters or 295 feet. While you may make a longer run and get it to work, this is not recommended.
Motherboard: MSI G45 | CPU: Intel i7 4790K | RAM: 16GB G.Skill DDR3 | SSD: 2x Samsung 840 Evo 256GB | Graphics: EVGA GTX 1080 FTW | PSU: Corsair HX650W | Cooler: Cooler Master Hyper 212 Evo | Fans: 6x Corsair SP120's | Case: NZXT H440 Razer Edition | OS: Windows 10
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5213494
It really depends on your internet speed and type but a random CAT6 cable would be fine too. I Use CAT7 just because it was cheap when i purchased it and it seems to be faster than a CAT5. If you have Internet like Googles Fiber then a CAT7 for sure but if you have like 60mbps down then a CAT 6 will do nicely.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5213504
I heard powerline is slower than wireless
nope unless you have AC and there arent many walls in between. I get 116% of the speed I pay for on powerline (I pay for 25 im getting 29)
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5213779
Truth, especially with current day wireless technology.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5213991
You have no idea how dumb you just sounded.  Your ISP's internet speed has no, I REPEAT NO, impact on your local networks speed.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5213994
ok I may have not said it clearly. I meant it didnt bottleneck my network speed sto the outside world which has much more impact on me.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5213997
The whole point of a fast local network isn't so you can transfer at the same speeds as your ISP.  Your LAN should be lightning fast compared to your ISP.  Power line adapters simply don't offer that.  Wired connections are obviously the best option with current wireless options being damn near close.  Powerline is quite literally a jump away from Wireless AC.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5214386
That really depends on the distance and any obstructions.
I'm unable to connect to my routers wifi from my room but powerline allows me to use my internet connection to its full potential and stream HD video around my whole network.
Poweline will never beat a physical cable but against wifi its a much better option at longer distances
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5218597
Cat 5/e should be more than enough for any residential line. (Unless you intend to transfer from server > pc on a local network etc..)
If you have a number of bandwidth heavy devices I would suggest Cat 6 which is only slightly more expensive and would future proof your connection.
As for shielded cable, you always want this. If you go for un-shielded and place the wire near light or power outlets, it can result in interference and therefore  a lower quality connection.
Connor Freebairn - ConnorFreebairn@newman.cumbria.sch.uk
IT Technician & Certified computer geek.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5218657
I go with cat 6a now, because it doesn't cost a lot more and is 1000mb standard.
Literally you pay for the extra few bucks and bam unless you get over 1gbit connection you'll be set.
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5218893
Lol. The vast majority of networks use unshielded cables. UTP is already fairly resistant to interference.
Future proof? He's buying a long patch cable. It's not going in the wall.
Forgot to add: Shielded cabling requires proper grounding. There isn't enough interference in residential applications to warrant the effort and expense of shielded cabling.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5219063
You can use CAT5e (DO NOT use standard CAT5) but at this point I would go for CAT6 or CAT6a since the price difference is usually minimal and they are shielded better. Over longer runs, copper wire tends to have the characteristics of an antenna, so the extra shielding will prevent signalling interference.
Monoprice, Cable Matters, and Mediabridge are what I tend to use (in no specific order) and have all been excellent.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5220959
I guess I always assume to much  :P , I host around 4 rack servers and loads of network enabled devices from my address. It's important that I have a stable connection at all times, this is why I use fast Cat6 Shielded cables.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5222118
Short answer: For 150 Feet, it literally does not matter. (Note: Except Cat5. Never use Cat5. It's outdated and doesn't support Gigabit.)
The maximum cable runs for Cat5e all the way to Cat6a or Cat7, are 100 meters (approximately 330 feet). You're less than half of the maximum cable run.
In your case, you could use pretty much any variation of Cat5e, Cat6, Cat6a, or Cat7. All support Gigabit over the distances you're running, and you shouldn't need to worry about shielding. Although, shielding and Solid Core are both useful for longer runs, so it wouldn't hurt.
(Please remember that Cat6e doesn't exist, and if someone is trying to sell it to you, it's not a real standard, so you have no idea what you're getting)
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5225538
Cat5 is limited to 100 Mbps (Gigabit is 1000 Mbps), so under no circumstances should anyone ever use Cat5 today. Also, the spec difference between Cat6 and Cat7 is almost negligible - Both are rated for Gigabit on 100 meter runs, and 10Gigabit for 55 meter runs (possibly longer). Though I would suggest Cat6a over Cat6, if price is similar. You will likely see no speed difference at all between Cat6 and Cat7.
It can be. Entirely dependent on the quality and age of your internal electrical wiring in the building. It also depends on the strength of your Wifi signal, amount of obstacles, etc.
See above - Powerline can DEFINITELY be slower than Wireless AC or even Wireless N. It simply depends on many factors. In ideal conditions for both, Wireless AC is straight up faster though, since Powerline rarely goes faster than 500 Mbps theoretical top speeds, and most have 100 Mbps ethernet jacks on them anyway.
https://linustechtips.com/topic/386248-ethernet-cable-help/#findComment-5225618
