Hey there,
Haven't been very active on here,so please excuse the chunkyness of this post mostly just browsing but I have an actual question that maybe someone can help me answer!
Some background first:
I live in the state of Maryland, USA.  Summers here can get pretty hot, and recently we've had some serious heat waves where I am.  I run a (reference cooler design) EVGA GTX 660.  At the moment I'm not overclocked.  Right now according to Precision X, just idling at my desktop, my GPU clock is at 324MHz, and I can't see my memory clock.  The temperature is hovering around 26-27 °C (My room is on the lower side because I have my blinds closed.)
My question is this;
In my situation, would underclocking my GPU reduce heat output? I'm thinking no because it's already idling low, but correct me if i'm wrong.  And also, what about gaming? If I wanted to try and reduce heat output while gaming, should I just lower some of my graphical settings? Anything you can contribute is greatly appreciated.  Thanks!
You can't take your GPU idle clock any lower without modding the BIOS. In addition, it cannot be lower than ambient temperatures - it's physically impossible.
Yay Maryland! I live north of Baltimore!
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
Underclocking won't reduce heat in idle state, as you expected. You could try setting a custom fan curve.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
Would lowering my in-game setting help?
It could.
:D
i7 8086k @ 5.3Ghz / 32GB DDR4 Trident Z RGB @ 3733Mhz / Aorus GTX 1080 11Gbps / PG348Q
