War Thunder Max Graphics Requirements?
Go to solution Solved by CommandMan7,
Thanks, this is a question from a buddy. We were just wondering if we should get the 750 ti or 270 to run the game at max. So I'm guessing that the 750 ti should do max 1080p just fine?
I actually had the 750 TI before my 970, and The only differences between 750 TI and 970 are tree and grass distance, and minimum framerates. But 750 TI will not max it out, you should move to 960 if you want it maxed.
Wondering what's cpu and gpu requirements to run this game maxed out at 1080p (around 60fps and no aa)
BRRRT!
PC
  • ASUS TUF GAMING B550M Plus
  • Ryzen 5 5600X undervolted
  • Gigabyte VISION OC RTX 3070 undervolted
  • 32GB Teamgroup Dark Alpha 3600 MHz CL18
  • Corsair TX750M
  • Fractal Design Meshify C Mini
Sim Equipment
  • Logitech Extreme 3D Pro & Thrustmaster TWCS Throttle
  • Logitech G27 with pedals and H-shifter
  • TrackIR 4
https://linustechtips.com/topic/383472-war-thunder-max-graphics-requirements/
I can run it full blast @ 1440p with an i7-4790K and a Gtx 980. Average fps: 110 -140
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
http://www.systemrequirementslab.com/cyri/requirements/war-thunder/11603/?p=r
reccomended : CPU: Dual Core 2.4 GHz
CPU Speed: Info
RAM: 4 GB
OS: Windows Vista/7/8
Video Card: Nvidia GeForce 460 or higher, AMD Radeon 55XX series or higher
Sound Card: Yes
Free Disk Space: 11 GB
lolol i mean 1080p and just around 60 with high/max settings. do you have a grasp of what one would need to run that?
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
http://store.steampowered.com/app/236390/
See the recommended setting, it should allow you to play the game nicely. Can you show us your PC specs?
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
CPU Speed: Info
RAM: 4 GB
Sound Card: Yes
I looked at that recommended specs but I'm pretty sure that it wont be enough to run it at high or max
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
My 970 runs it @ 1080 maxed out no AA.
I am conducting some polls regarding your opinion of large technology companies. I would appreciate your response.
Microsoft Apple Valve Google Facebook Oculus HTC AMD Intel Nvidia
I'm using this data to judge this site's biases so people can post in a more objective way.
See it's kinda hard to answer that because it's too specific :P
Reccomended should let you run it pretty high at 1080p, seems like the best reference for you.
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
your 750ti should be plenty
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
Not that much really. An i5 and 960 should do it easily. A 270/270X should do well as well.
EDIT: This should give you an idea. It's not hard to run.
Great, this graph is what I needed, where is this from?
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
alright, great info, thanks
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
GTX 770/GTX 960 for everything maxed, dips into 50s in arcade mode intows, also in tall grass(<-tanks) and also in lots of clouds in planes
my experience with : clouds med, motion blur off, haze off, everything else is maxed
        Sample Text ( ͡° ͜ʖ ͡°)
