Hi guys,
I've built many computers for other people, but never one for myself. Today, I am going to replace my 2011 MacBook Pro with something more substantial.
Budget:
$1000 with rebates
I'm in the US
Aim:
99.9% workstation use
      - Web browsing
      - Writing school papers
      - Rendering and creating stuff in Premeire Pro CC 2014 (mostly using this), After Effects CC 2014, Cinema 4D and Photoshop CC 2014.
      - Cinema 4D R16
      - Maybe like a tiny bit of gaming (web games, indie games @1080p). A good GAMING gpu is not a must.
Other random stuff:
I'll be running 1 1080p 60hz monitor for now, maybe I'll add 1 more.
I already have Keyboard, Mouse and Monitor
I would like it to be a mATX build / case. Simple colors, black/white. Window is must.
I like quiet. Noctua cooler is a must (or another cooler w/ Noctua fan).
I've kinda narrowed it down to i5 or Xeon e3 (low end) w/ higher end GPU; or a i7 or Xeon e3 (high end) with a lower end gpu (750ti). I was wondering if GPU acceleration / rendering is worth it with Premiere, AE and C4D. Is 16gb ram needed too?
If we are going with "i5" or "i7" cpus, then I would like overclocking. If we go with Xeon e3, then no (obviously).
I would like it to be in mATX as I said before. I had my eyes set on a Air 240, or a Node 804. How is the Define Mini? Quiet(ness) would be nice!
Thanks so much,
nicon
https://linustechtips.com/topic/382204-1000-render-machine/
I don't know whether cinema 4d supports rendering with graphics cards, I personally have my pc for rendering (blender), too. What's inside? Gigabyte GAming G1 970 and xeon 1231v3: works pretty well.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5160773
i'd like to mention that noctua isnt the only quiet fan brand anymore. my bequiet dark rock advanced C1 is dead quiet even at max speed.
that's true
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5160776
True, but beQuiet is hard to find in the 'states.
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5160803
There is also Cryorig, Phanteks and others.
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5160883
If you are OK going bigger than mATX you could look at dual Westmere-EP hexacores you can pick them up very cheap and you'll end up with 12 physical + 12 logical cores, they are getting a bit old but they are still great bang for buck, especially in parallel processing like a lot of rendering is. I'd look at x5650's as a minimum but you often find good deals on x5670's or x5660's because of the locked multiplier you are limited to bclk overclocking so the x5675's and above generally bump up in price a bit. Just make sure you read up on the motherboards, some require you to re-pin the PSU connectors and some have early revisions that only accept x5500's while x5600 support was only added in later revisions.
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5160915
How does this sound?
CPU: Intel Xeon E3-1276 V3 3.6GHz Quad-Core Processor  ($329.99 @ SuperBiiz)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($64.75 @ OutletPC)
Motherboard: ASRock Z97M OC Formula Micro ATX LGA1150 Motherboard  ($99.98 @ Newegg)
Storage: A-Data XPG SX900 64GB 2.5" Solid State Drive  ($60.98 @ Newegg)
Video Card: Asus GeForce GTX 750 Ti 2GB STRIX Video Card  ($157.99 @ SuperBiiz)
Case: Corsair 350D Window MicroATX Mid Tower Case  ($89.99 @ Newegg)
Total: $997.64
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5160999
That Xeon isn't worth that money. Go 4790k, or ditch it and go 5820k, from which you could benefit a little
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5161007
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($325.99 @ SuperBiiz)
Total: $993.64
Generated by PCPartPicker 2015-06-07 12:20 EDT-0400
or
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($372.95 @ SuperBiiz)
CPU Cooler: Corsair H80i 77.0 CFM Liquid CPU Cooler  ($69.99 @ NCIX US)
Motherboard: ASRock X99M Extreme4 Micro ATX LGA2011-3 Motherboard  ($189.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 750 Ti 2GB WINDFORCE Video Card  ($109.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($34.99 @ Newegg)
Power Supply: Raidmax 530W Semi-Modular ATX Power Supply  ($42.99 @ SuperBiiz)
Total: $993.26
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5161154
You must have 16GB RAM, 8GB on DDR4 isn't worth it for this work.
The top system looks better suited.
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5161263
@AliveGhost13
This is pushing the budget...
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($54.99 @ Micro Center)
Total: $1088.86
Generated by PCPartPicker 2015-06-07 12:57 EDT-0400
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5161407
The H80i is expensive for what it is. A $30 cooler will be just as good + quiet. Then, get a cheaper XFX, Antec HCG, any Seasonic PSU as the Raidmax isn't very good
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5161413
Maybe 212 Evo w/ Noctua Fan?
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5161499
Not worth it
The BeQuiet Pure Rock is cheap and quiet, better than the 212 Evo
https://linustechtips.com/topic/382204-1000-render-machine/#findComment-5161521
