I've lost the power cord to my printer, but I have a power cord from one of my external hard drives that will plug into it with no problem. Question is; the printer power supply is listed at AC 100-240 V, 50/60 HZ and on the power cord I want to use it is listed as 125V-7A, can I use this cord with the printer? Here's what the cord looks like, by the way.
Thanks in advance!
https://linustechtips.com/topic/376983-power-cord-question/
If it fits, just jam it in there and see if it works. That's how I've always used power cables :)
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
https://linustechtips.com/topic/376983-power-cord-question/#findComment-5096401
if it fits, yes
https://linustechtips.com/topic/376983-power-cord-question/#findComment-5096403
Yeah, if on the last cord there wasnt a transformer, if there was then you'd be shooting 120v into it. It's probably good then
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/376983-power-cord-question/#findComment-5096405
LOL
Um, I'm not wanting to see a fireworks show!
The power brick is built into the bottom of the printer and the input is rated at 120V. The power cord is listed at 125V.
That means the cord can take 125V.
https://linustechtips.com/topic/376983-power-cord-question/#findComment-5097152
Same here.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/376983-power-cord-question/#findComment-5097161
Well for more serious business stuff you might want to check the cable, cause some will start a fire if the cable isn't thick enough, but a printer (hopefully) doesn't consume that much energy and can probably be safely used
Useful threads: Code of Conduct || Unofficial LTT Beginners Guide || Forum FAQ
CPU: Intel Core i5 4440 GPU: GTX 760 MOBO: Asrock Z97 Anniversary RAM: 8GB Adata @ 1600 Mhz Case: Define R4 SSD: Kingston V300 128 GB
HDD: 1TB Seagate Barracuda NAS: 3TB Seagate Barracudas in RAID 1 PSU: EVGA 600B (600W 80+ Bronze) Display: LG 23MP75 (1080p IPS @ 60hz)
https://linustechtips.com/topic/376983-power-cord-question/#findComment-5097171
