Corsair K95, k70 razer blackwidow chroma and other rgb mechanical keyboards, i need to pick one
Solved by ImBleu,
I have a K70 RGB (w/ browns) and I love it, the software is very nice for corsair as well with several pre-designed settings to cycle through if you want, or per-key backlighting / speed adjustments and when you dig a little deeper you can do everything with it. Not to mention downloading themes off the corsair forums for other lighting modes.
Razer's software side is quite good and corsair doesn't lag that far behind, but Corsair is miles ahead in build quality.
