Best card for OpenGL? (Linux)
Go to solution Solved by osbios,
Also what card would you pick?
Like the others already said. This cards are on two different performance levels, and with this prices the 290 is the way to go.
Most likely I will get a 290 myself. I just wait for the 300 line to be release and then look how prices will develop.
EVGA GeForce GTX 960 4GB PCI-Express 3.0, "SSC", ACX 2.0+, Witcher 3 (digital voucher)
2.699,-
Lagerstatus:
Stocked.gif 11 stk. på lager.
Finansieringspris: 251,-/mnd. (12 mnd.)
Totalpris 12 mnd. 3.851,-
Varenummer: 839637
Produsentens varenr.: 04G-P4-3966-KR
Vekt m/emballasje: 1.25 kg
Produsentens garanti (md.): 36
VS
Sapphire Radeon TRI-X R9 290 4GB "OC" PCI-Express 3.0, DL-DVI-D + DL-DVI-D, HDMI, DP, UEFI
2.849,-
Lagerstatus:
Stocked.gif 64 stk. på lager.
Finansieringspris: 265,-/mnd. (12 mnd.)
Totalpris 12 mnd. 4.018,-
Varenummer: 836487
Produsentens varenr.: 11227-13-20G
Vekt m/emballasje: 1.44 kg
Produsentens garanti (md.): 24
If it was in DirectX only this would be a no brainer but the issue is AMD has not been able to make a single Linux driver that can reach 60+ FPS on the most amazing games that is currently ported to Linux it cant even reach 50 FPS in many games which is not good at all. What about the 960? Well a regular 960 does 100+ FPS in the majority of the games I have seen they tested head to head and even scoring twice as good to three times as good. AMD may fix their drivers so should I go red and hope they fix it or go green and stay safe?
EVGA 960 pros:
*Best GTX 960 on the planet?
*Better performance NOW. (OpenGL)
*Less power and needs smaller PSU.
EVGA 960 cons:
*Less future proof?
*Weaker on the Windows side.
Sapphire 290 pros:
*May get better drivers in the future?
*Stronger on Windows games.
Sapphire 290 cons:
*Needs better PSU.
*Poor performance on Linux.
*Some games it cant render mesh with out doing some work.
After you read all this VOTE! :)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/375573-best-card-for-opengl-linux/
r9 290 kewl, 960 is not even close.
wait what nvidia has better opengl performance? since when is that the case.
using linux when windows 8.1 and ssd's exist just feels like a massive self handicap to me and I will never understand that.
http://www.phoronix.com/scan.php?page=article&item=bioshock-inf-18&num=2
The poor 290 is bottlenecked by the awful Catalyst Linux drivers...
if you want to stick with linux then ( why) I would get the 960. never bet on amd to fix anything they might go bankrupt while trying to.
As it looks now yes but AMD may fix it? Their last fixes did increase Metro from less than 30fps to near 60fps. =S
So did people even read before they vote here? :<
Anybody?
Anybody?
I did, and i still voted for the R9 290. This is not coming from any fanboy bias, like much of the responses from your previous thread. Most of the GPU's i own are in fact Nvidia GPU's, but price:performance favors AMD in this scenario. The Price:Performance of a GTX 960 is terrible when compared to other cards in its price range. I currently use a GTX 770, which is roughly 10-15% faster than a GTX 960, and on equal footing with the GTX 960 if you count maxwell GPU's having better driver support, and my card still runs games pretty terrible on linux when compared to windows. This is more likely due to the nature of the porting. I can see why fglrx might be a source of the problem (lets face it, AMD has not updated their drivers in a very, very long time) and you may still have a better experience on an Nvidia GPU, but the GTX 960 will seal your fate when it comes to 1080p gaming. You will not exceed 1080p on that card in 90% of the games you play, and some games, even at 1080p, will be too demanding for that card to max.
The best advice i could give you, would be to either wait for prices to drop to get the best piece of hardware for your dollar, or save up just a little more and get a GTX 970, or find a cheap GTX 780 for sale. I do not know the prices of computer hardware in Norway, but if its possible for you to get a working GTX 780 for cheap, i would go for it.
My (incomplete) memory overclocking guide:
Does memory speed impact gaming performance? Click here to find out!
On 1/2/2017 at 9:32 PM, MageTank said:
Sometimes, we all need a little inspiration.
Sorry to say, but if you want to play AAA titles you still have to use windows.
I didn't use the catalyst driver for over a year now. And the open source drivers did pretty well for my 7870.
But I hat to use bleeding edge drivers and OpenGL infrastructure(mesa). And that's not something you want to do when you just want it to work. I did it mainly because the open drivers are better in some aspects and as a tester to find and report bugs.
Also newer cards like the 290 will have worse open driver support then my 7870.
I understand if you need to get work done but why Linux if you're looking to game? You do know that windows has tons more games right?
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
Well the 290 also do need a bigger PSU but its still cheaper than a 970 even then. But if AMD do not fix these issues I am gonna be worried. :(
Also does the OCed 960 help at all? (I do know it wont beat the 290 but I think it beats the 280 and I know it beats 285X and its not to far behind 280X.)
Yeah I know but I want to use Windows only when I have to because that thing slows down so much if I use it for all my daily nonsense. :P
Well I also want to use the internet without using the CCleaner and Anti-Virus all the damn time! xD
Not hating on Windows but that thing should be more secure and not slowdown. :(
Well even though Linux viruses are very low, there are still some that exists in the wild.
Were you using windows on a mechanical hard drive before?
I run the same windows installation i've had for over 2 years now (windows 7 64 bit ultimate) and it has yet to slow down on me using an SSD. I run CCleaner every month or so but aside from that, nothing else needs to be done to maintain it. TRIM is enabled by default for me, and you do not need to defrag SSDs.
As for the GPU question, the GTX 960 is known to OC very high if you have one of the better cards with better power delivery, but it still will not bridge the gap between the R9 290. If you are worried about power consumption, i should mention that i have several friends that run 290X's on 500w PSU's, and they game all day on them. Here are some video's of the card being ran on benchmarks with a wattage meter testing power draw of the system from the wall:
 (290 X)
(290)
That being said, one could easily run a GTX 960 on a very high quality 300w PSU with absolutely  no problems. My advice would be to go with which ever one you want the most. While the 290 is the superior card in a majority of the standard usage situations, it is up to you to get what you want for your dollar. I would hate you see you get a 290 and be unsatisfied with it. If you do not plan to game beyond 1080p, i am sure the GTX 960 will be fine for you for the most part.
Well what about a 970 with blower fan?
http://us.msi.com/product/vga/GTX-970-4GD5-OC.html#hero-overview
Its about the same price as the MSI 290 Gaming edition + 750W PSU. So if I where to go with one of those?
MSI vs MSI? The AMD drivers still has issues and the 970 only has 3.5 so I most be careful not to buy VRAM hog games. =S
I have never had a single SSD to date but that will change with next PC! ;)
My MSI laptop does have a 250GB SSD but the morons who made it put OS on the HDD...
 (290 X)
(290)
Yes I know it runs fine on 500w but for how long? A guy I know said the PSU will lose 5-10% per year of its performance so higher W is better yes?
Also MSI 290 Gaming vs http://us.msi.com/product/vga/GTX-970-4GD5-OC.html#hero-overviewwhich is better? :D
One has bad AMD drivers and causes global warming kinda. The other is shitty overpriced and only has 3.5GB of VRAM... :P
To me both sucks! But which is less shit? :D
Moved to here: (part 3)
http://linustechtips.com/main/topic/376045-round-3-best-gpu-for-linux-290-vs-970/#entry5085501
