I'm looking to build my first pc (http://uk.pcpartpicker.com/p/gKQyrH) and intend to upgrade to a better GPU such as a 970 or 980, add an ssd and a new case like the 350D, and possibly a CPU+mobo upgrade. Would I be better off with the 4350, or should I get a 6300 instead?
Also, would I be able to over clock on this mobo, because if I could I would probably get the 6300 and over clock?
Thanks
https://linustechtips.com/topic/374396-first-build-advise/
I would atleast get the 6300, please don't buy a PC which is only there to be upgraded every half year, tell us your budget, location and use and we will help you
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5063969
What's the system being used for?
Is the optical drive really necessary?
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5063970
I'm looking to build my first pc (http://uk.pcpartpicker.com/p/gKQyrH) and intend to upgrade to a better GPU such as a 970 or 980 and possibly a CPU+mono upgrade. Would I be better off with the 4350, or should I get a 6300 instead?
Thanks
Welcome to the Forum.
1) What are you wanting to do with this build?
2) What's your location (I'm assuming you're in the UK)?
3) What's your budget?
Sig under construction.
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5063976
Pretty sure a 970'or 980 would be a huge bottleneck to that cpu
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5063979
I'm a teen and this is gonna be a gaming build as well as possibly some video editing. My budget is around £500/£550 for the lot- tower, monitor keyboard etc.
I'd prefer to get a slightly lesser GPU and a better cpu+mobo that will last longer, and I need a quad core for far cry 4
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5064010
I'd say this
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor (£55.03 @ Scan.co.uk)
Motherboard: MSI A78M-E45 Micro ATX FM2+ Motherboard (£41.46 @ Amazon UK)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1600 Memory (£45.54 @ CCL Computers)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£38.34 @ Aria PC)
Video Card: MSI GeForce GTX 750 Ti 2GB Video Card (£94.99 @ Ebuyer)
Case: Cooler Master N200 MicroATX Mid Tower Case (£33.54 @ Aria PC)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply (£38.99 @ Novatech)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer (£9.59 @ Scan.co.uk)
Wireless Network Adapter: TP-Link TL-WN725N 802.11b/g/n USB 2.0 Wi-Fi Adapter (£6.96 @ Aria PC)
Monitor: Dell P2214H 60Hz 21.5" Monitor (£85.00 @ Amazon UK)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse (£26.28 @ Ebuyer)
Other: Windows 8.1 (£74.99)
Total: £550.71
Generated by PCPartPicker 2015-05-26 22:09 BST+0100
Also, later down the road, you may want to get a cooler. I'd suggest something like this: http://uk.pcpartpicker.com/part/zalman-cpu-cooler-cnps5xperforma
Its cheap and does the job.
"an obvious supporter of privacy"
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5064082
I'd say thisPCPartPicker part list / Price breakdown by merchantCPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor (£55.03 @ Scan.co.uk) Motherboard: MSI A78M-E45 Micro ATX FM2+ Motherboard (£41.46 @ Amazon UK) Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1600 Memory (£45.54 @ CCL Computers) Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£38.34 @ Aria PC) Video Card: MSI GeForce GTX 750 Ti 2GB Video Card (£94.99 @ Ebuyer) Case: Cooler Master N200 MicroATX Mid Tower Case (£33.54 @ Aria PC) Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply (£38.99 @ Novatech) Optical Drive: Lite-On iHAS124-14 DVD/CD Writer (£9.59 @ Scan.co.uk) Wireless Network Adapter: TP-Link TL-WN725N 802.11b/g/n USB 2.0 Wi-Fi Adapter (£6.96 @ Aria PC) Monitor: Dell P2214H 60Hz 21.5" Monitor (£85.00 @ Amazon UK) Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse (£26.28 @ Ebuyer) Other: Windows 8.1 (£74.99)Total: £550.71Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-05-26 22:09 BST+0100
I would be buying this to upgrade the GPU and add an ssd so would an 860k be a bottleneck to something like a 970/980?
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5064121
Yes it would... And the AM3+ CPUs would as well...
One more thing, when will you get a GPU?
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5064131
You won't be doing much CPU upgrading with a board with no or little VRM cooling
Is this a bit too expensive?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  (£48.93 @ Amazon UK)
Motherboard: Asus H81M-PLUS Micro ATX LGA1150 Motherboard  (£41.77 @ Scan.co.uk)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card  (£112.00 @ Ebuyer)
Case: Cooler Master K280 ATX Mid Tower Case  (£21.48 @ Amazon UK)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  (£47.66 @ CCL Computers)
Monitor: BenQ GL2250HM 60Hz 21.5" Monitor  (£89.98 @ Amazon UK)
Total: £563.52
Generated by PCPartPicker 2015-05-26 22:40 BST+0100
- CPU can be overclocked on this motherboard
- R9 270, great gaming GPU for mid-end 1080p gaming
- Quality, XFX (Seasonic) PSU
Rest is self explanatory
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5064306
Total: £563.52
I was looking at the G3258 but I really want to play far cry 4 so was going for an and quad core or higher
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5064334
Ah I see, understandable. Write that off then
https://linustechtips.com/topic/374396-first-build-advise/#findComment-5064349
