4690k is best for gaming
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5058532
4690k hands down
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5058543
Depending on the game title them extra threads help but only ever so slightly. Nothing worth paying +$100 extra for the i7 unless he does CPU heavy tasks other than gaming.
Name 1 game that uses those extra threads
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5058570
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5058577
Oblivion, Far Cry 2, it's not entirely based around thread utilization but having enough to offload the OS and all of its services. Like said it's nothing drastic, we're talking 1-5 FPS variance in games so as stated it's nothing I would pay the extra $100 for but it does help varying from title to title (some games actually run worse with HT).
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5058580
If you already are paying so much for the GPU, then you don't want to cheap out on the CPU. DON'T GO FOR AN i3 IMO. As others stated an i5 4690k or even an i7 4790k would do the job. If you're only focusing on gaming, then go for the i5, however if you plan on doing some content creation, (e.g. video/photo editing) then the i7 will be better as the hyper threading will help you a lot.
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5058634
I would go for the i7 4790k to future proof a bit, extra threads could come in handy, don't wanna be stuck with something if you need more later.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5058878
I'd say if you plan on doing a lot of multi-tasking (gaming + various other things) to go for an i7 -- the HT will mean that whatever you're running isn't having to compete nearly as much for the CPU. The i3 is hyper-threaded, though, so it'll give 4 threads, the same as an i5. The i5 can just do things better as it has 4 physical cores instead of 2 physical and 2 logical. So the i5 is best if you don't anticipate a lot of multi-tasking, but spring for an i7 if you can afford it.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5058967
Minimum i5 4440, or anything better
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/373957-cpu-for-gtx-980/#findComment-5061914
