Help with choosing a keybaord
Fricey
So my other mechanical keyboard was #### and it broke so I'm looking for a good replacement under $80.
Can it be on microcenter.com because im buying from their
Coolermaster has good quality mech keyboards.
I highly recommend CM Quickfire Pro/rapid (i myself have red switches, but that's up to you)
I think rapid is better than pro, but they're both amazing.
Man $140 is something I know $80 is a little cheap but that is kinda my budget
What switch do you want? Check out the link in my sig for info on that then report back. $80 will cover about 3 different switch types.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
I would like the green black and normal. But any would work
Greens, Blacks and "normal?" What do you mean by normal? Also, greens and blacks are in no way similar so I doubt that you would like them the same.
Im just fine with any of them and by normal i mean cherry mx.
Which Cherry MX!? Cherry MX Greens, Cherry MX Blacks, and what else?
The Clears.
https://www.alternate.nl/html/product/information/page.html?articleId=1101863&channel_code=544&product_code=84895202&utm_source=google&gclid=CjwKEAjw7YWrBRCThIyogcGymQsSJAAmz_nd6zI9H4xTtWT8XO3qX9LM_Kle01lFFkjc_7elwngPHxoCzQXw_wcB
http://www.amazon.com/Storm-QuickFire-Rapid-Tenkeyless-Mechanical/dp/B0068INSUM/ref=sr_1_1?ie=UTF8&qid=1432517147&sr=8-1&keywords=quickfire+rapid
The quickfire pro/rapids are around 70-90bucks.
The Clears.
That'll cost no less than $150 and on WASD or Ducky or something rare.
Greens are slightly heavier and lots louder and even rarer.
