For some time I used HOST file adblock and chrome's adblock. Until I cared about this awesome comunity. The host prevents any connection for the entire computer (blocks ads from IM clients, and all browsers) it displays an "connection failed" picture instead (when using explorer), but the rest of the page is intact. Something like this:
This is not the problem! The real problem is that I need this kind of adblock back, but I also want to support Linus! I'm very used to pause adblock in chrome before clicking Linus's new Youtube video. But this HOST file overwrites Chrome's adblock...and there is nothing I can do to have IE and everything else but Chrome controlled by HOSTS.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/37011-bypass-a-host-file-help/
What version of Adblock? Adblock Plus?
https://linustechtips.com/topic/37011-bypass-a-host-file-help/#findComment-475880
https://linustechtips.com/topic/37011-bypass-a-host-file-help/#findComment-475893
If you install Adblock Plus, you can simply disable it on individual pages.
https://linustechtips.com/topic/37011-bypass-a-host-file-help/#findComment-475902
Nope, you don't get it! Adblock plus for chrome blocks the ads already blocked by HOSTS. If I pause it/whitelist a website, it doesn't show the ads. I need chrome's connection bypass the dns verification loaded from the hosts file.
https://linustechtips.com/topic/37011-bypass-a-host-file-help/#findComment-475945
Thn don't use a host file adblocker. The way the host file works, there is no way, as far as I know, to override it on some sites but not others. To remove it completely, remove the entire contents of the HOST file which is somewhere in the windows folder (system32?).
HTTP/2 203
https://linustechtips.com/topic/37011-bypass-a-host-file-help/#findComment-480029
This is what I did... We really need an standalone adblock for the entire computer, wich we can control from a tray icon...
https://linustechtips.com/topic/37011-bypass-a-host-file-help/#findComment-480438
Correct.
When something wants to know the IP address of a host, it checks the HOSTS file to see if it is contained there, if it isn't it queries a DNS server. HOSTS can not be overridden unless you know the IP address of where you want to reach (which isn't actually overriding it).
https://linustechtips.com/topic/37011-bypass-a-host-file-help/#findComment-481974
The location
C:\windows\system32\drivers\etc\hosts
http://linustechtips.com/main/topic/8752-making-a-network-more-responsive/?hl=%2Bhosts+%2Bfile#entry97366
I did a little write up about how to make your network abit more responsive (works for some sites, not for others).
But basically if you want to edit your hosts file, I describe how to do it in there.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/37011-bypass-a-host-file-help/#findComment-482023
