Refreshing build, 660W Seasonic enough?
Solved by Aniallation,
So, after getting sucked into folding@home (thanks to LTT!), I decided I wanted to go ahead and update my pc this year, rather than wait. Anyways, I was wanting to get an i7 4790k, dual gtx 970s and probably switch from air cooling to one of the AIO water cooling options. I currently have a Seasonic 660W 80+ Platinum psu, and was wondering if this would be enough, or if I need to bite the bullet and upgrade the PSU as well. http://pcpartpicker.com/part/seasonic-power-supply-ss660xp is a link to the psu.
It will definitely be enough as long as you're not doing extreme OCs (>5GHz on CPU, etc)
