Laptop Storage Upgrade Questions.
Solved by ZetZet,
~250gb
http://pcpartpicker.com/part/crucial-internal-hard-drive-ct256mx100ssd1
http://pcpartpicker.com/part/samsung-internal-hard-drive-mz75e250bam
http://pcpartpicker.com/part/crucial-internal-hard-drive-ct250bx100ssd1
~500gb
http://pcpartpicker.com/part/crucial-internal-hard-drive-ct512mx100ssd1
http://pcpartpicker.com/part/samsung-internal-hard-drive-mz75e500bam
http://pcpartpicker.com/part/crucial-internal-hard-drive-ct500bx100ssd1
BX100 is the slowest of the bunch, but it's the most efficient and cheapest.
Samsung is the fastest of the bunch ( does not really affect you since your laptop probably has SATA2 anyway)
MX100 is just a good ssd.
Btw jupiter has no surface so having a road should be complicated.
