Hi!
I was considering getting be quiet! Dark Rock Advanced C1 but pcpartpicker says that it doesn't fit in my case (nzxt s340). What cooler would you suggest? I'll be using i7 4790k and I plan to overclock it :)
My bugdet is about 50€ not more than 100€ and I'll be ordering in Germany.
Thanks for your advice
CPU: i7 5820K Motherboard: MSI x99A SLI PLUS RAM: Corsair Vengeance DDR4 2800mHz (4x4gb) GPU: MSI GeForce  GTX 980Ti Case: NZXT S340 Storage: 840 Evo 120gb and WD Blue 1TB  PSU: EVGA SuperNOVA G2 850W CPU Cooler: be quiet! Dark Rock 3
GTX 980 Ti (reference card) High Idle temps solution -
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/
Get a decent 120mm AIO like the H80 or Seidon 120V. They are relatively cheap and take up a single fan slot of your choice.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984686
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984703
Noctua NH-U12S fits in the case.
That one looks nice yes, also noctua has great reputation :) Will consider this one :)
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984719
Do you already have the 4790K? If not, do you really need it? You could always drop it to a 4690K and get a better cooler like the H100i, Dark Rock 3, R1 Universal or NH-D15..
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984727
They are cheap, but is it worth it? Do cheap watercoolers cool the cpu better than midrange air coolers?
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984730
Coolers like these cost more and are louder and perform worse than air coolers for that price.
Get be quiet! Shadow Rock 2, it has 160mm height and your case support 161mm.
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984740
No not yet. I am still just making variations online so I can order the right things for my setup.
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984741
Well what are you doing with your build?
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984750
On most things I have allready decided. Msi z97 gaming 5, i7 4790k, GTX 980 ... I'll be using my setup for video editing and 3d animations. I will be ordering within a month, therefore i'm looking for perfect parts to suit my build.
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984765
Are you going to OC it much? Because I got a watercooled i7 4790K and mine get's up to like 70-70 when I'm playing (my CPU is 4.8GHz)
And I've hear a lot of people complaining about the temps on that CPU :)
GPU: RTX 2080 Super        Keyboard: Corsair K70 MK.2 RGB
CPU: i7-9700K        MouseLogitech G PRO Wireless
RAM: 16 GB Corsair Vengance PRO                                                         Headset: Corsair HS70 PRO Wireless
PSU: CX650F        MousepadCorsair MM500 Extended 3XL
MOBO: Asus Prime Z390-A        ControllerDualSense 5
Case: Lian Li Lancool II        CameraCanon EOS M50
Monitor: Samsung Odyssey G5        CoolingCorsair H100i Platinum
The white Rabbit        MicrophoneTrust GXT 252+
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984809
From time to time I'll OC it to test its limits but otherwise on daily bases it will be overclocked a bit, just to speed up things :)
EDIT: What watercooler do you use?
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984825
Ah okay :) Well it automatically boosts itself to 4.4 which is a fine clock with low temps (in my computer though) :)
I use this pump/res: http://www.inet.se/produkt/5331204/reservoar-ek-d5-vario-x-res100-incl-pump
And this CPU block: http://www.inet.se/produkt/5331234/block-ek-supremacy-evo-original-csq
My overclocked Gigabyte GTX 980 G1 Gaming has a temp of 39 when running extreme benchmarks, so yeah the cooling is fine xD But the CPU likes to go up high :P But when I get the new motherboard I'll check and see if it's anything wrong with the Thermal Paste :)
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4984918
Well I doubt that I'll buy custom water cooling (just because of my budget). For now I'll probably stay on air cooling and maybe in the future in case of upgrade I'll do some kind of custom watercooling.
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4985203
for air cooling look at the noctua nh-d14, noctua nh-d15 or dark rock pro 3.
keep the i7 4790k, it will crap all over the i5 4690k when overclocked.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4985480
I will keep an i7, don't worry. I'll take a look on those coolers. I need to check some reviews and side by side testings :) Thanks!
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4985543
welcome mate :).
https://linustechtips.com/topic/368222-looking-for-cpu-cooler/#findComment-4985738
