Please put it in a PCPartPicker, people,like me on a tablet. it's quite hard to open tons of links
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Pc part picker. Please.. and the mobo if it needs an update wont work
@Aniallation   :P
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
Al budget and location?
I would get this build it will perform much better in games.
http://pcpartpicker.com/p/7Q7N7P
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($37.99 @ Newegg)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($229.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($29.99 @ NCIX US)
Total: $608.39
Generated by PCPartPicker 2015-05-16 13:31 EDT-0400
Stronger than the build you posted.
This motherboard needs a bios update.
You could pair it with a 4130 which is the same as the 4160 but with 200 mhz less and saves you the hastle of BIOS updating.
i looked up at pcpartpicker and said i needed to update the bios of the mobo so i could use the cpu, my question is: ¿i could update the bios without the processor o barely use it to update it?
btw if u think i could change some components for better one or just because its horrible... just let me know xD
Since the motherboard doesn't support USB BIOS Flashback, if it doesn't come with a compatible BIOS no you can't use the motherboard without updating, and you can't update without a compatible processor.
"Rawr XD"
Ew, XFX. Would be a much better idea to get a 280 non-X and get a better PSU. An i5+280X build with a 500-W1 is unbalanced.
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card  ($179.99 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case  ($47.99 @ Micro Center)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($58.99 @ SuperBiiz)
Total: $601.39
Generated by PCPartPicker 2015-05-16 13:35 EDT-0400
"Rawr XD"
It says that some may need a bios update. I don't even really understand how that works.
@MikusArah
This is a far better build than you originally posted. Better cpu, equivalent GPU with a little more longevity thanks to it's 3gb of vram, and the like.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
Still, it's a 280x and i agree he could use a better PSU but it will work.
Some retailers BIOS update the motherboards that need it by themselves and ship it updated, otherwise if it's a factory shipped mobo it would need the updating.
PCPartPicker part list: http://pcpartpicker.com/p/TqkQnQ
Price breakdown by merchant: http://pcpartpicker.com/p/TqkQnQ/by_merchant/
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory  ($49.99 @ Newegg)
Storage: PNY CS1111 120GB 2.5" Solid State Drive  ($49.99 @ Micro Center)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($22.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($36.99 @ SuperBiiz)
Total: $654.38
Generated by PCPartPicker 2015-05-16 13:36 EDT-0400
You will be happy that you put your os on an ssd when you started the build and not trying to copy over from an hdd
And if it isn't updated then you will need a compatible cpu to update it and then you can use any cpu. (With the same chipset.)
PCPartPicker part list: http://pcpartpicker.com/p/7KZb6h
Price breakdown by merchant: http://pcpartpicker.com/p/7KZb6h/by_merchant/
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($66.98 @ Newegg)
Video Card: MSI GeForce GTX 960 2GB Video Card  ($179.99 @ SuperBiiz)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($36.99 @ Newegg)
Total: $633.37
Generated by PCPartPicker 2015-05-16 13:40 EDT-0400
WHats wrong with the psu again?
Compatible CPU, in that case a haswell CPU seeing as the 4160 is  a Haswell Refresh one.
For example 4130 = Haswell, 4150,4160=Haswell Refresh.  4440 = Haswell, 4460 = Haswell Refresh.
Ok thanks.
Total: $633.37
Low build quality, there are better PSUs for this price range.
