I have a Gigabyte 980, which has card sag. It is known that it always does this due to the size so I would just like gather some of the communities opinions on how to fix this. I am just worried because it's already starting the show that it's beginning to sag.
https://linustechtips.com/topic/367121-card-sag/
It is really an aesthetic, and it is not like it will snap in half randomly. TBH there are not any un-ugly ways of fixing card sag as im assuming the card already has the gigabyte backplate, in which case im surprised it is sagging.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/367121-card-sag/#findComment-4971434
Yeah it's not terrible but if you look at the top it definitely sags. It also at a slight angle, like a ramp.
https://linustechtips.com/topic/367121-card-sag/#findComment-4971450
Acrylic braces can look very good when done properly.
That actually looks quite good, but does it only attach to one pcie screw, or does it overlap the rear io panel of the gpu?
https://linustechtips.com/topic/367121-card-sag/#findComment-4971527
My strix 970 also has quite a bit of sag and it's bugging me :/
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/367121-card-sag/#findComment-4973447
Hire a "Steve" to hold your graphics card up :ph34r:
http://imgur.com/gallery/g9O0jNx
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/367121-card-sag/#findComment-4975657
Reminds me of this I made a while back: post-128204-0-91041700-1431748016_thumb.
I call him 4096MB
https://linustechtips.com/topic/367121-card-sag/#findComment-4975686
Found Puget's brace, they use 2 pci screws. Won't be able to use them due to 1 pci space between my sli configuration.
https://www.pugetsystems.com/store/item.php?cat=Case+Mods&id=10588&com=d41d8cd9&que=
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
https://linustechtips.com/topic/367121-card-sag/#findComment-4975741
I just spent 10 minutes looking for this to post, I really should read the entire thread before posting things.
Personally I'm gonna go with Puget's option, they have some things I need anyways.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/367121-card-sag/#findComment-4976017
Reminds me of this I made a while back: [snip]
I call him 4096MB
Oh, ey see wat chu ya thar!!
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/367121-card-sag/#findComment-4976030
Must suck if you got a evga 980 that didnt come with a backplate, that would sag so fast.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/367121-card-sag/#findComment-4976102
my strix has a backplate and still sags like a mofo. It's bending from where the PCB meets the io plate so backplates don't always helps Card sag
and a car thread !
https://linustechtips.com/topic/367121-card-sag/#findComment-4979152
