Would this motherboard benefit from a sound card? Even if the sound card is 5.1 channels.
https://pcpartpicker.com/part/asrock-motherboard-fatal1tyh97killer
Not really, as the sound integrated is more than enough for pleanty of things
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/362694-sound-card-question/#findComment-4915661
no
unless you notice static or EMI from your speakers or mic, there is no need for a sound card
https://linustechtips.com/topic/362694-sound-card-question/#findComment-4915742
I would just stay with the integrated sound chip from the motherboard. If you want a noticeable difference then an external amp and DAC would be better.
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
https://linustechtips.com/topic/362694-sound-card-question/#findComment-4915744
Since it is a Fatal1ty branded board the audio should be decent enough without having to further invest in AMP/DAC deals.
https://linustechtips.com/topic/362694-sound-card-question/#findComment-4915758
