Posted May 5, 2015 Is the amd worth considering in a budget orientated build? I'd prefer a GTX but if the Radeon is more cost efficient I would definitely consider it. Intended pc use is mainly gaming, cad and programming, light photo/video editing Thanks Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 5, 2015 Is the amd worth considering in a budget orientated build? I'd prefer a GTX but if the Radeon is more cost efficient I would definitely consider it. Intended pc use is mainly gaming, cad and programming, light photo/video editing Thanks Where do you live? QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE My Setup: Desktop Spoiler CPU: Ryzen 9 3900X CPU Cooler: Noctua NH-D15 Motherboard: Asus Prime X370-PRO RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory) Storage: 1050GB Crucial MX300, 1TB Crucial MX500 PSU: EVGA Supernova 750 P2 Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional Displays: Asus MG279Q FreeSync OC, LG 27GL850-B Main Laptop: Spoiler Laptop: Sager NP 8678-S CPU: Intel Core i7 6820HK @ 2.7GHz RAM: 32GB DDR4 @ 2133MHz GPU: GTX 980m 8GB Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD OS: Windows 10 Pro Chassis: Clevo P670RG Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II Thinkpad T420: Spoiler CPU: i5 2520M RAM: 8GB DDR3 Storage: 275GB Crucial MX30 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 5, 2015 $200 and $350 which one will win? the $270 290x will Thats that. If you need to get in touch chances are you can find someone that knows me that can get in touch. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 5, 2015 The GTX 970 is a faster card, has better power consumption and will likely run cooler under load depending on what version you choose, but the R9 290 is a lot cheaper and performs almost as well anyways. If you can take advantage of CUDA acceleration, possibly consider the GTX 970. If you cannot, and the extra money could be well spent on improving a part of your system that may need improving (such as the PSU), I'd get the R9 290. Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850 Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 5, 2015 Is the amd worth considering in a budget orientated build? I'd prefer a GTX but if the Radeon is more cost efficient I would definitely consider it. Intended pc use is mainly gaming, cad and programming, light photo/video editing Thanks If it is between the 970 or the 290, I'd shoot for the 290 on a budget, and the 970 for performance. If this were between the 970 and the 290x, however, I'd shoot for the 290x all day long. Cheaper and faster. CPU: Intel i5-4690k RAM: 16gb Corsair Vengance Pro DDR3-2400 Case: NZXT S340 Cooler: CM Hyper 212 Evo Storage: Intel 730 SSD PSU: EVGA 850G2 Mobo: Asus Z97-A 3.1 GPU: 980ti G1 OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 6, 2015 $200 and $350 which one will win? the $270 290x will http://pcpartpicker.com/part/powercolor-video-card-axr92904gbd5tdhev- Cheapest R9 290 is $250 before rebate, $220 after. http://pcpartpicker.com/part/sapphire-video-card-1003614l- Cheapest R9 290X is $300 before rebate, $270 after. http://pcpartpicker.com/part/pny-video-card-vcggtx9704xpbhttp://pcpartpicker.com/part/zotac-video-card-zt9010110p - Cheapest GTX 970s are $300-$310 with no rebate. Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850 Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 6, 2015 Author Where do you live?Australia Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 6, 2015 http://pcpartpicker.com/part/powercolor-video-card-axr92904gbd5tdhev- Cheapest R9 290 is $250 before rebate, $220 after. http://pcpartpicker.com/part/sapphire-video-card-1003614l- Cheapest R9 290X is $300 before rebate, $270 after. http://pcpartpicker.com/part/pny-video-card-vcggtx9704xpbhttp://pcpartpicker.com/part/zotac-video-card-zt9010110p - Cheapest GTX 970s are $300-$310 with no rebate. rebates do work... Thats that. If you need to get in touch chances are you can find someone that knows me that can get in touch. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 6, 2015 rebates do work... When did I say they didn't in this thread... Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850 Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 6, 2015 Hmm, well, 970 trades blows with 290x, and 290 is slightly (i think ~10%) slower than 290x. But, 290 should be considerably cheaper, especially for a budget build. I'd go with 290 (if the difference is big enough). If the difference in negligible, then 970 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 6, 2015 If you in Aus you should go buy the R290, but GTX970 are better at 1080p but when at 1440p and 4k r290 catches up. Magical Pineapples
