ATX/Micro ATX Case Restrictions - Why?
JMaio
Is it possible to stick an ATX motherboard e.g. ASUS Z87-DELUXE in what is called a "Micro-ATX" case such as the Corsair 350D?
Would it be possible? If not, why? Would it simply not fit, does it not have the necessary standoffs?
Thanks for reading,
-JMaio
The case is physically too small and there are not enough expansion slots. Also, the necessary standoffs are not there.
Edit - words.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
An ATX motherboard has 7 expansion slots (12" tall) and a MicroATX case only accomodates boards with up to 4 expansion slots (9.6" tall).  The extra height on an ATX board would extend over 2" into the power supply area, or through the bottom of the case if the power supply is mounted at the top.
You could but it would not be properly screwed in and there would be no space for the power supply. And not enough expansions slots of course
I'm working on cutting down my Bitfenix Shinobi as much as I can while still fitting an ATX mobo in it. At the moment it looks like the overall size will be about 15% smaller than a 350D. The problem with ATX cases is the positioning of the PSU and optical drive bays, they pretty much determine how big the case is.
Laptop Lenovo Thinkpad X220 - CPU: i5 2420m - RAM: 8gb - SSD: Samsung 830 - IPS screen Peripherals Monitor: Dell U2713HM - KB: Ducky shine w/PBT (MX Blue) - Mouse: Corsair M60
Audio Beyerdynamic DT990pro headphones - Audioengine D1 DAC/AMP - Swan D1080-IV speakers
