Noctua NH-D15 is it too big for me?
EndlessOyster
Im planing new build and I want to cool it with the D15 but its a big cooler and I was wondering if you know if it would fit.
Does anyone have knowledge if the cooler will;
Block the RAM?
Block the first PCI slot?
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler
Motherboard: MSI X99S SLI Krait ATX LGA2011-3 Motherboard
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2400 Memory
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card
Case: Phanteks Enthoo Luxe ATX Full Tower Case
The Dick of the audio page!
I have this cooler. You will be fine. Worse case dont use one of the fans. It will fit with no problem tho.
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
Seems to fit fine in this review of the case. It will probably overhang one or two memory slots, but it's not a big deal with your low-profile kit. Could be a bit of a bother if you need to swap out memory later on.
Thats really helpful, Thanks.
