Simple(?) Cpu Question
im not gonna bring in variables and all the other math equations im talking simplistically as possible
is 4 2.0ghz cores better then 2 4.0ghz cores.
this is clearly hypothetical but..an interesting question ive never received a clear answer on.
and 2 things
1. no im not buying a new cpu...this is just a simple question. i dont need one "made to fit my needs" its just a question.
2. would this even be a possible question with the realms of cpu's we have?
assuming you're talking about the same manufacturer and same architecture then the answer is ... sometimes
it all depends on how the program itself is coded. if it is coded in a way that will fully use all cores then 4 at 2@ghz would be more efficient than 2 at 4. but unless all 4 cores run at 100% all the time you wouldn't really see a benefit
